scratching/grinding noises, clutch? |
Jun 14, 2013 - 5:48 PM |
Enthusiast Joined Jul 5, '09 From Katy/houston Currently Offline Reputation: 16 (100%) |
so today my brother drove the car back and i noticed that the car is making really loud scratching/grinding/scraping type noise. kinda like u get when u try to shift gears without pressing the clutch.
it only happens when u press the clutch pedal. when i let go of the clutch, it goes away. didnt drive too much after that, just around the neighbourhood, drives normal so far.i did put it in 3rd and floored it to see if it slips but didnt. the thing thats confusing me is that it happens only with the pedal is pressed and not when its free...ussually shouldnt it be the oposite if the clutch is bad? maybe im wrong any input appreciated. car info: 2nd gen 3sgte sway with most likey stock gt transmission (bought the car like this so that all i know) any thing i should check for? -------------------- For Sale:OEM tail lights - make offer
Jun 14, 2013 - 5:54 PM |
Moderator Joined Jun 29, '08 From Denver Currently Online Reputation: 59 (100%) |
Probably a bad throw out bearing.
Jun 14, 2013 - 6:10 PM |
Probably a bad throw out bearing. i just started reading up on that, how difficult is that to replace and how much $$ am i looking at? -------------------- For Sale:OEM tail lights - make offer
Jun 14, 2013 - 9:49 PM |
Throw out bearing $20. The labor to replace it around $200-300
Jun 14, 2013 - 10:38 PM |
While you're at it if you don't know the car's history just go ahead and get a clutch kit and replace all of it.
Lo-Fi Version | Time is now: January 9th, 2025 - 7:25 AM |
