> Question, Governer
post Jun 19, 2013 - 12:15 AM
Poonicus
Joined Apr 24, '13
From Tomball, TX
Do our cars have governer? Or anything in the ECU that tells the car to not preform as well as it should/could?
"As a professor of science, I assure you we did, in fact, evolve from filthy monkey-men." -Prof. Farnsworth
post Jun 19, 2013 - 2:25 AM
Box
Joined Feb 23, '12
From Warrior, AL
JDM ECU's have a speed limiter of 180 km/h.
2001 Miata LS 5-speed
post Jun 19, 2013 - 3:32 AM
Julian_Navia
Joined Nov 10, '11
From Rockville, MD
I belive the ST is governed at 110 mph. Though I'm not sure about the other models
Edit: Sorry Box it didn't actually cross my mind at the time that 180k and 110mph are about the same
This post has been edited by Julian_Navia: Jun 19, 2013 - 3:34 AM
Dude I almost had you
post Jun 19, 2013 - 3:51 AM
Box
Joined Feb 23, '12
From Warrior, AL
Only the JDM cars are governed, and yes 180 km/h equals 112 mph. Given a long enough race in a straight line ours car would be "faster" against the JDM models. tongue.gif
post Jun 19, 2013 - 1:21 PM
Poonicus
Joined Apr 24, '13
From Tomball, TX
It just feels like it could have a high top speed.
post Jun 19, 2013 - 1:35 PM
richee3
Joined Jun 29, '08
From Denver
I've had an ST auto and GT manual at their top speeds. Neither hit a governor. They both just ran out of power to go any faster.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Jun 19, 2013 - 2:19 PM
Poonicus
Joined Apr 24, '13
From Tomball, TX
Oh well then it might just my imagination.
post Jun 19, 2013 - 7:23 PM
BonzaiCelica
Joined Apr 24, '08
From Orange County, CA
St has a governor from fsctory cause the tires it come with cant handle high speed. I prob cud of got the st too 120 mph
post Jun 20, 2013 - 12:32 PM
Poonicus
Joined Apr 24, '13
From Tomball, TX
That's all I can get my gt to.. At only 5000 in 4th gear, drops down to about 4k if I put it in 5th but won't go any faster, that's why I was curious.
post Jun 21, 2013 - 6:40 PM
travisxcore
Joined Mar 24, '11
From 704
QUOTE (Poonicus @ Jun 20, 2013 - 1:32 PM) *
Manual GT maxes out at 120mph and that's because of the S54. My Celica has been up to almost 140 when the previous owner had it (on the auto trans).
This post has been edited by travisxcore: Jun 21, 2013 - 6:40 PM
post Jun 21, 2013 - 7:49 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
It's only limited by gearing and engine power in the USA. Above a certain speed you lack the gearing and power to go any faster.
post Jun 21, 2013 - 8:27 PM
Poonicus
Joined Apr 24, '13
From Tomball, TX
Oh ok so the 5sfe with stock tranni couldn't handle it?
post Jun 21, 2013 - 9:39 PM
Bitter
Joined Mar 11, '06
add more power and you can go faster.
post Jun 21, 2013 - 10:05 PM
travisxcore
Joined Mar 24, '11
From 704
*Add more rev and you can go faster.
Its not that the 5s doesn't have enough power, its the fact that (like any other car) it has a rev limit, hit that and its game. The 3s will hit 135ish on the S54 before it redlines. If the gearing was longer, it could go a lot faster (like the auto that maxes out past 140mph).
post Jun 21, 2013 - 11:16 PM
Poonicus
Joined Apr 24, '13
From Tomball, TX
So, all I would have to do is get it regeared?
post Jun 21, 2013 - 11:25 PM
Box
Joined Feb 23, '12
From Warrior, AL
Why do you need to go faster than 130 anyhow?
post Jun 22, 2013 - 8:02 AM
Bitter
Joined Mar 11, '06
QUOTE (travisxcore @ Jun 21, 2013 - 10:05 PM) *
Longer gearing means you need more power though since you're past a 1:1 ratio and the power the engine makes is being reduced to the wheels to make them spin faster. There's no free lunch, you can't spin something faster AND make more power, it's one or the other. Lower gears multiply the engine power, highest gear reduces it. In a 1:1 gear what you have at the crank is what you get at the wheels (except drive train loss).
<iframe width="853" height="480" src="http://www.youtube.com/embed/QPaUJfA1KsY" frameborder="0" allowfullscreen></iframe>
post Jun 22, 2013 - 8:31 AM
momentai99
Joined Nov 19, '12
eh my manual 94 gt with advanced timing and ported and polished heads can max the speedo, I run out of power a little above 145 it seems. The best part about this car is it handles incredibly at even 100mph, I love it. I also gutted my power steering and don't use the A/C so it frees up that little bit of power loss from them which is more significant than people think in engines only putting out so much power like these.
post Jun 22, 2013 - 12:42 PM
Bitter
Joined Mar 11, '06
The factory speedo is not calibrated to read accurately over about 85 mph, and if you're running anything other than stock sized tires and wheels the accuracy is further thrown out the window. You're more likely doing 115-118 actual speed, not the 145 indicated. Verify with a GPS.
post Jun 23, 2013 - 1:46 AM
momentai99
Joined Nov 19, '12
QUOTE (Bitter @ Jun 22, 2013 - 12:42 PM) *
My gps is always on, 145 is accurate. I had coolant steaming out of my engine when I did it, I never pushed it that far again after. Being my other car is about 400hp 145 is kind of normal being we live on back country roads with nothing around I don't go easy on any of my cars. My wife isn't even phased by it anymore it's funny.
Lo-Fi Version Time is now: November 23rd, 2024 - 8:00 PM
