> 4a-ge swap, to do or not?, power benifits?
post Jan 24, 2004 - 3:55 PM
Digndoug
Joined Aug 20, '03
From Annapolis, Md
ok, i came across a fairly good deal on a 4a-ge engine, as far as i know its only th engine, no ecu, trans orv anything else. i have an st and as iv read so far its closer of all the swaps for an easier project, im planing to do this myself, iv been working on cars and engines for the past 10 years. so im just starting off, but can my trans fit direct up to fit, and is this even worth doing?? like what is the exact power ratings?
post Jan 24, 2004 - 4:05 PM
BEEFSTEW800
Joined Dec 30, '03
From Atlanta
check the stickys
post Jan 24, 2004 - 4:12 PM
BigEdge169
Joined Nov 18, '02
From Texas
Maybe this link to Coomer's experiences might help you. From everything I've heard, its a much more difficult swap than everyone makes it out to be so be careful and don't get yourself in too deep and then have a car that doesn't run.
http://www.6gc.net/forums/index.php?showtopic=8914
post Jan 24, 2004 - 5:01 PM
If you can find a competant mechanic or if you're competant enough to do it yourself, you should be fine. Most of my troubles have been due to my mechanic's total lack of knowledge and experience. Colin(Xpander) had a shop in Florida do his swap, and it took them about a month to do it.
Some mechanical issues that you'll run into is that the 4A-GE's power steering pump is mounted on the exhaust-side of the engine rather than the intake-side, like on the 7A-FE, so you'll either have to have a shop extend the hard lines or make new ones, or you can mount your power steering pump on the intake-side of the engine, which requires cutting and welding part of the intake manifold. Colin used his 7A-FE power steering pump and mounted it on the intake-side of the engine, so that if his power steering pump ever goes out, he can simply get one for the 7A-FE, rather than sourcing one from the twenty-valve 4A-GE, which could be very difficult.
Also, you'll need to use a longer throttle accelerator cable, or you can modify your intake manifold to accept the cable on the driver's side rather than the passenger side. Colin's shop did this when they did his swap.
There are probably more issues that I'm forgetting about, but a good mechanic should be able to do this swap for you if you're not able to do it yourself. One thing that is kind of a pain is finding wiring information, as most of it is in Japanese, or is for the blacktop AE111 4A-GE. Theoretically, you should be able to find some wiring info in English in Australia, but I've yet to talk to a twenty-valve owner who's been able to get this information.
Also, the tranny that's mated to your 7A-FE right now will bolt right up to the twenty-valve 4A-GE, though the 4A-GE's tranny uses different gear ratios to take advantage of the engine's different characteristics. The stock axles work as well.
As far as power, the AE101 4A-GE engine is rated at 160 horsepower at 7400 RPM, and doesn't have much torque. I've read that the engine produces 120 lbs.-ft. of torque at 5200 RPM, but I can't be sure if this information is correct. The AE111 4A-GE produces 165 horsepower at 7800 RPM, due to lighter internals, a higher redline, and other enhancements and improvements to the engine. It supposedly produces the same amount of torque, but it's at 5600 RPM rather than 5200.
As far as whether or not it's worth doing, Colin was happy with his swap, but said that his car was only marginally faster than a ST204(USDM GT.) Other people with fifth generation Celicas have said that it made their cars much faster. Once mine is done, I'll let you know whether or not I think it's been worth five months without the car, constant aggravation and sadness, a ruined paintjob, and lots of money to get this engine into my car.
post Jan 24, 2004 - 6:40 PM
toyotaspeed_90
Joined Jan 22, '04
From bellingham, WA
well, it also matters which version of the 4a-ge you found....
the 20V's are going to be a bit harder... you will need the ecu and wiring.... all previous 4a-ge's and the 7a-fe are all non vvt/vvt-i......
if you found a bluetop (first gen) 4a-ge, then you will need an ecu as well, disconnecting the t-vis doesn't do the engine any justice... it was designed to use it.....
post Jan 24, 2004 - 7:40 PM
Digndoug
Joined Aug 20, '03
From Annapolis, Md
Thanks alot to every one, that does make a dif knowing all that info, maybe, il just stick to cars i know more about, ie chevy...hehe and i found the silver top 20v for 400 bucks on e-bay http://cgi.ebay.com/ebaymotors/ws/eBayISAP...item=2454536883
post Jan 24, 2004 - 8:24 PM
QUOTE (Digndoug @ Jan 24, 2004 - 4:40 PM)
If you were to get that, you'd still need the AFM, ignitor, ECU, wiring harness. wink.gif
So are you deciding to not swap the twenty-valve 4A-GE into your car then?
post Jan 24, 2004 - 11:28 PM
Digndoug
Joined Aug 20, '03
From Annapolis, Md
not at this exact moment, my car has 133k on it, so im hoping not tomorrow or anything. but i was doing my research so, im not stuck when it comes time, i allso have a chevy 1500 extend cab long bed as a work truck, an i just blew the engine at 280k so im also thinking about swaping a new engine in that soon an i was also thinking about making it a show truck or somthing, with bags an all, you dont see tomany. and im also rebuilding my outboad motor on my searay before summer. also as im scrapping my bimmer. to many things to do, while still trying to do school. but any info when you get finished up all your, well lets say nightmare, will def help. Thanks again
post Jan 25, 2004 - 8:20 AM
qatar11
From Lake Orion, MI
ITs my expierence that the importers are not being careful with the harnesses when they import 4A's here for whatever reason.
It does depend on which version that you get since there are like elenventy billion differnt types, and books for them are scarce.
I would reccomend getting a 3SGTE motor.
-Mike
mjcoury@gmail.com
Team Reynolds Style
Celica Blog
Celica Wiki
post Jan 25, 2004 - 1:12 PM
QUOTE (qatar11 @ Jan 25, 2004 - 5:20 AM)
As would I, if you're allowed to. Since my parents pay my insurance, they wouldn't let me get anything with a turbo, and insurance would kick me off if they found out that I had a turbocharged car.
From what I've read, it'd have been only marginally more difficult to swap a 3S-GTE into my AT200.
post Jan 25, 2004 - 9:35 PM
FallenHero
Joined Dec 26, '02
From Alabama
Just what is TVIS?
post Jan 25, 2004 - 9:43 PM
QUOTE (FallenHero @ Jan 25, 2004 - 6:35 PM)
Just what is TVIS?
This article isn't too in depth, but explains what it is and even has a helpful diagram. wink.gif
Lo-Fi Version Time is now: November 27th, 2024 - 7:46 PM
