Enthusiast ![]() Joined Feb 26, '12 From Parkersburg wv Currently Offline Reputation: 1 (100%) ![]() |
What all axels will fit a 3sge tranny with LSD
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 24, '08 From Orange County, CA Currently Offline Reputation: 33 (100%) ![]() |
I wish this board was so smart that everytime someone tried to creat a new thread with a question that was already asked in a post it would search that subforum the member is posting it in by word or by certain frases. Totally awesome feature, just saying.
Btw normal gt axles will work -------------------- Group buy to replicate Narrow E series transaxle parts
I wish this board was so smart that everytime someone tried to creat a new thread with a question that was already asked in a post it would search that subforum the member is posting it in by word or by certain frases. Totally awesome feature, just saying. Btw normal gt axles will work Do you know where on the tranny it says what tranny it is, my gt axels are to small in diameter |
![]() Moderator ![]() ![]() ![]() ![]() ![]() Joined Nov 5, '07 From New Zealand Currently Offline Reputation: 3 (100%) ![]() |
The 3S-GE came with the E56 & the S54.
which transmission do you have? -------------------- |
The USDM S54 axles aren't as beefy as the JDM S54 axles that came with the BEAMS, but they are 100% interchangeable. Which generation 3S-GE do you have? That will help us figure out which trans you have and therefore which axles you need.
Whats the purpose of the thicker axles, how much thicker are they? Can someone take side by side pics. Wud the ss3 axles actually put more power to the wheels or just cause more weight on the front of the car?
I'm not exactly sure what gen 3sge, I bought someone else project and they did not know. I do know it is not beams I will try post pics later today of engine and transmission
Was it from someone here on the forums, specifically this car?
http://www.6gc.net/forums/index.php?showtopic=89926 If its not a BEAMS, it's more than likely a 3rd gen 3S-GE. Really easy to spot based on the intake manifold... and the BEAMS are super easy. Gen 1 ![]() Gen 2 ![]() Gen 3 ![]() Gen 4 ![]() Gen 5 ![]() -------------------- "Employ your time in improving yourself by other men's writings, so that you shall gain easily what others labored hard for." -Socrates. Even Socrates told us to use the search button!
Yea that was it,
Whats the purpose of the thicker axles, how much thicker are they? Can someone take side by side pics. Wud the ss3 axles actually put more power to the wheels or just cause more weight on the front of the car? see sticky http://www.6gc.net/forums/index.php?showto...mp;#entry842489 in the trans/axle code: S54-06D. the 6 is used for the axle. as you can see from that thread, there is a bit of difference in the bearings. Benny as for your transmission. To find out if it's the E56. its the same case as the GT4's E154F but without the transfer case, and has a plate on the timing belt side, it also supposedly came factory with an external oil cooler. Requires a different clutch & axle setup to that of the S54. My thoughts are following the guys with the 3S-GTE & E153 setup E56 gearbox ![]() -------------------- |
I'm pretty sure it is the E56, what clutch set up goes with that one?
I guess now I need to find some beams axels or 3she axels |
The BEAMS came with an S54 bolted to it, so it uses the same axles as a USDM ST204 instead of the axles that the 3rd gen 3S-GE/E56 use.
Whats the purpose of the thicker axles, how much thicker are they? Can someone take side by side pics. Wud the ss3 axles actually put more power to the wheels or just cause more weight on the front of the car? x2!! -------------------- Group buy to replicate Narrow E series transaxle parts
Mine seams to be set up to take an external oil cooler
for the clutch setup:
You can use the same clutch cover as you would with a beams/5S-FE swap You need a specific clutch disc: 31250-32110 or you possibly might be able to use the same disc when the 3S-GTE swappers use the E153 The axles on the SS-II SS E56 are model specific as its using a E series gearbox and superstrut. I cant remember off the top of my head when others have done a beams swap with the S54-06D if they've used their factory axles or the new axles with non-superstrut setup. If they used the new ones you should be using your (if you got them) E series axles, but you cannot use the S series axles. Bonzai, try reading my above post first. -------------------- |
Norberto where are the pics? PICS DONT WORK
for the clutch setup: You can use the same clutch cover as you would with a beams/5S-FE swap You need a specific clutch disc: 31250-32110 or you possibly might be able to use the same disc when the 3S-GTE swappers use the E153 The axles on the SS-II SS E56 are model specific as its using a E series gearbox and superstrut. I cant remember off the top of my head when others have done a beams swap with the S54-06D if they've used their factory axles or the new axles with non-superstrut setup. If they used the new ones you should be using your (if you got them) E series axles, but you cannot use the S series axles. Bonzai, try reading my above post first. Well I didn't get the e series axels so ill have to get those but then what outlets woul be best for the least amount of work, meaning switching hubs ect... |
Have a look at the details of a E153 swap, that a few people have been doing. As being an E series aswell, there should be a lot more similarities that should help
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 11, '08 From Auckland, New Zealand Currently Offline Reputation: 0 (0%) ![]() |
on the subject of what fits what, anyone think a beams rocker cover could fit a 3s-gte gen3 head? lol
i'm changing to caldina intake manifold and front mount, the gen3 cover is ugly lol -------------------- Mike W
Lo-Fi Version | Time is now: February 17th, 2025 - 4:49 AM |
