> 7GC 6 speed gearbox in 6GC, Is that easy to do?
post Jul 1, 2013 - 7:04 AM
onnaj
Joined Sep 6, '12
From Holland
Hello,
I've converted my 7AFE to a 4AGE 20V Blacktop, but i've kept my C52 gearbox. I want to change to either the Corolla AE111 (C160 gearbox i believe) or the Celica 7G gearbox.
Is it easy to use the 7G gearbox? Can i use my old transaxles with this gearbox? What else do i need to make it happen?
Did search the forum but couldn't find the answer.
Thanks!
post Jul 1, 2013 - 8:23 AM
i think its because you are pioneering this effort. its a c series tranny, it may work. but i guess you may be on your own.
post Jul 1, 2013 - 10:24 AM
C60 mates up to the 7A, and has been used with success. I can't find a link to where or who, but it is doable. The C160 is unheard of like Nico said.
post Jul 1, 2013 - 10:29 AM
kurt95gt
Joined Aug 23, '11
From kenton ohio
I remember that thread
Its an older build
Tweak dropped a 4agze an a c60 into a st they said it worked great
94 st hatch my daily driver
n
post Jul 1, 2013 - 11:10 AM
onnaj
Joined Sep 6, '12
From Holland
post Jul 3, 2013 - 6:22 AM
nope tweak is long gone...
post Jul 3, 2013 - 6:26 AM
onnaj
Joined Sep 6, '12
From Holland
post Jul 5, 2013 - 1:17 AM
BonzaiCelica
Joined Apr 24, '08
From Orange County, CA
C60 n c160 have same gear ratios, c160 had helical lsd. They are same size but have diff transfer, whatevr thats called that connects to engine block
post Jul 5, 2013 - 1:29 PM
^ Bell housing?
This post has been edited by SwissFerdi: Jul 5, 2013 - 1:30 PM
post Jul 5, 2013 - 2:53 PM
BonzaiCelica
Joined Apr 24, '08
Yea bell housing. I have a friend with a 88 corolla gts who did 4age 6 speed swap. Now since i know that then it should fit into at200 chassis just fine no
post Jul 6, 2013 - 3:30 AM
onnaj
Joined Sep 6, '12
From Holland
So swapping the bellhouse will be it? Can I use my own axles /drive shafts?
Thanks!
post Jul 7, 2013 - 4:00 PM
BonzaiCelica
Joined Apr 24, '08
the 6 speed that came with his 4age blacktop 20v is the one that comes stock with the engine. its the c160. so i'm not sure what axles you can use
post Jul 8, 2013 - 3:48 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
ii was at my buddys shop all last week. they were building a mean ass 4A-GE and bolted it up to a C60 from a 7Gen. they used the bell housing from the MR2 trans and gears and body housing from the C60.
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Sep 12, 2018 - 8:53 PM
BonzaiCelica
Joined Apr 24, '08
this is what it looks like if ya'll ever interested in it...
it sits slightly forward as you can see by pics so it'll give you more clearance to run a 4age blacktop itb setup without worrying about it hitting firewall.
IMG-20180528-WA0002 by Justin Towers, on Flickr
IMG-20180528-WA0003 by Justin Towers, on Flickr
and inside an AE92 Corolla. oh and the bell-housing adapter plate and custom flywheel.
IMG-20180219-WA0001 by Justin Towers, on Flickr
IMG-20180217-WA0000 by Justin Towers, on Flickr
post Sep 17, 2018 - 5:25 PM
Did you swap, details?
post Sep 19, 2018 - 10:23 AM
BonzaiCelica
Joined Apr 24, '08
QUOTE (njccmd2002 @ Sep 17, 2018 - 6:25 PM) *
no, but i can put details of cost from the guys in south africa who have done it and the beams dual vvt-i is the guy in panama. price are different for sure... expensive and for a few hundred $ more you can get a dog box i believe.
post Sep 23, 2018 - 1:25 AM
BonzaiCelica
Joined Apr 24, '08
C60 Transmission = $800 (give or take on condition)
Custom Flywheel and Bell housing Adapter Plate = $1500
Clutch Kit = $350.
as far as axles go. the guy in Panama says the S54 axles are plug and plate, but im skeptic of it until i see pics....
he also said the c160 diff is different from the c60 transmission.. how so? doesn't make any sense to me.
post Sep 26, 2018 - 6:59 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
not sure how the C160 is different, maybe the linkage on the other side? maybe the gearing, LSD?
post Sep 26, 2018 - 11:50 PM
BonzaiCelica
Joined Apr 24, '08
QUOTE (Smaay @ Sep 26, 2018 - 7:59 PM) *
yea WAS thinking the same thing anyway. too expensive to justify the extra gear and gearing benefits. but if i had 10,000 monies i'd do it!
post Sep 30, 2018 - 11:37 AM
Bitter
Joined Mar 11, '06
From Way South Chicago
No oil drain issues from the head with the different angle?
Lo-Fi Version Time is now: February 16th, 2025 - 3:01 PM
