Colt State Park, Bristol, RI. Sept. 21 Meet!, Thats right, we're bringing this shiz BACK! |
Sep 17, 2013 - 4:56 PM |
My coupe does the same thing
I beleave mines due to a poorly balanced axle shaft since it started shortly after replacing my pass side axle I've had my wheels balanced multiple times an everything inspected by a friend when my alignment was done an everything else checked out fine Mine also comes an goes around 50+ an tends to be more frequent on rough roads -------------------- 95 gt coupe, v6 swap weekend toy
Sep 17, 2013 - 5:19 PM |
Enthusiast Joined Jul 7, '03 Currently Offline Reputation: 55 (100%) |
If you are thinking about attending this meet quit thinking and do it. I traveled from washington state in 07 for this meet.
I can say honestly I was a little aprehensive about traveling 3000 miles to meet people I had only talked to on the internet and a few times on the phone. I can say it was one of the best experiences of my life, the people are the best and the meet was a blast. If I had the time or money I would be there in a heartbeat. -------------------- JDM guy made me do it.
Sep 17, 2013 - 5:36 PM |
A/c is fixed. Vincent_Doggy cooling plate has been delivered. New radio will be installed before the meet. Hopefully the local Toyota dealership was able to come up with one of my new ball joints today. Should have everything ready to go just in time.
Sep 17, 2013 - 5:44 PM |
-------------------- 1995 GT::::Diffusing the Situation エキサイティングカーレーシングチーム! march 2010 COTM : 6GC feature 2014 : january 2015-2016-2018 COTM |
Sep 17, 2013 - 5:49 PM |
I've lost count of how many times I've had to have the system vacuumed and recharged in the last couple of years. Had to replace a couple of O rings this time though.
Sep 17, 2013 - 7:54 PM |
What is this A/C you people speak of?....
Sep 17, 2013 - 9:14 PM |
Anyone have experience with weird wheel wobble? It comes and goes depending on the road. Happens at anything above 50mph and sometimes doesn't happen at all. Tierod ends are old but still okay, tires are balanced (supposedly) and I've got two new axles now. Could it be an internal issue with the tires? Like the bands breaking? Trying to figure this out before the drive, and it only does it with these tires/wheels. I'm going to try swapping the rears with the fronts (they should be rotated anyway) and see what that does... But I'm trying to get ideas of what else to look for. Never have had an inconsistent shake before like this. Make sure your rims are hub centric. If they are not, you need to buy hub centric rings for them. Then have the wheels balanced again. Not every shop is good at balancing wheels. I have had mine done, and then went to a different shop to recheck them. The new shop told the that the guys at the other shop didn't know what they were doing. They re-balanced them, and I have had zero problems since. If all of these things check out and you are still having issues, then you probably have a bent rim. -------------------- 15PSI - 30MPG - Megasquirt Tuned
Sep 17, 2013 - 9:46 PM |
I am looking forward to this meet ! It's gonna be hellafun ! FYI, I have a CF hatch and hoood for sale and anyone who wants to pick them up before or after the meet, just let me know. They're looking for a good home ! With the meet just days away, just a reminder. I want to get these out of my garage asap. -------------------- |
Sep 17, 2013 - 10:38 PM |
Wish I had the money:(
Sep 17, 2013 - 10:46 PM |
Enthusiast Joined May 31, '11 From Rochester, NY Currently Offline Reputation: 5 (100%) |
Anyone have experience with weird wheel wobble? It comes and goes depending on the road. Happens at anything above 50mph and sometimes doesn't happen at all. Tierod ends are old but still okay, tires are balanced (supposedly) and I've got two new axles now. Could it be an internal issue with the tires? Like the bands breaking? Trying to figure this out before the drive, and it only does it with these tires/wheels. I'm going to try swapping the rears with the fronts (they should be rotated anyway) and see what that does... But I'm trying to get ideas of what else to look for. Never have had an inconsistent shake before like this. Make sure your rims are hub centric. If they are not, you need to buy hub centric rings for them. Then have the wheels balanced again. Not every shop is good at balancing wheels. I have had mine done, and then went to a different shop to recheck them. The new shop told the that the guys at the other shop didn't know what they were doing. They re-balanced them, and I have had zero problems since. If all of these things check out and you are still having issues, then you probably have a bent rim. I only have centering rings on the front wheels as I can't seem to find anymore. I ordered 4 back when I got the enkeis, but I forgot to take them off the wheels when I traded them. I centered the rears with my lug nuts though. Would it still cause vibration like that coming from the rear? Also, anyone going to the meet interested in a set of Eibach (red) springs on Koni Special D adjustable struts? I've got a used set (less than 30k miles on them at this point) that are still good. The rubber dust covers or baffles need to be replaced on a couple though. This post has been edited by RabidTRD: Sep 17, 2013 - 10:50 PM -------------------- 1994 Toyota Celica GT-S 5S-FE 190k Miles. Project car 1992 Toyota Celica GT 5S-FE 170k Miles. Daily driver/beater 1999 Toyota Camry LE 5S-FE 216K Miles. RIP You will be missed. *ASE Certified General Manager |
Sep 18, 2013 - 5:35 AM |
Price?
Sep 18, 2013 - 6:47 AM |
Enthusiast Joined Mar 8, '09 From Westport, MA Currently Offline Reputation: 6 (100%) |
Registered and legally drove the Coupe yesterday, things finally done after three years in the works can't wait for CSP guys! Feels weird driving it lol
-------------------- st205 powered ss3 coupe
Sep 18, 2013 - 7:16 AM |
Enthusiast Joined Mar 10, '11 From New Jersey Currently Offline Reputation: 1 (100%) |
I just want to thank my Celica for leading me to
such a great 6gc.net family. always having a member that can help out with any problem or just helping someone at my best of knowledge definitely grew a more family feeling for u guys ! So im extremely excited for this special gathering to actually have the chance to meet with the owners of these awesome cars. OAN: Yesterday on my way home from work i caught a flat tire. And with that being said, i just wanted to remind everyone to make sure they have a spare in there trunk, u never know what can happen, specially those with longer distance commute ! Taken off from work friday to prep my sexy lady up and give her her mani and pedi ! lol see u guys soon Forgot to add, Bring your cellphone chargers ! lol This post has been edited by CrossCudi: Sep 18, 2013 - 7:17 AM -------------------- 94' Celica GT Manual |
Sep 18, 2013 - 8:10 AM |
Sep 18, 2013 - 11:25 AM |
Weather forcast has improved to partly cloudy, with only 20% chance of rain!
Cant wait fir the weekend! -------------------- Former Team 5SFTE pro member ;)
13.6@108MPH, 5SFTE Powered |
Sep 18, 2013 - 12:01 PM |
If you guys don't make a deal bring them still we might pending my cash flow once we get there -------------------- 95 gt coupe, v6 swap weekend toy
Sep 18, 2013 - 12:45 PM |
Enthusiast Joined Apr 12, '13 From Bulgaria Currently Offline Reputation: 53 (100%) |
Anyone have experience with weird wheel wobble? It comes and goes depending on the road. Happens at anything above 50mph and sometimes doesn't happen at all. Tierod ends are old but still okay, tires are balanced (supposedly) and I've got two new axles now. Could it be an internal issue with the tires? Like the bands breaking? Trying to figure this out before the drive, and it only does it with these tires/wheels. I'm going to try swapping the rears with the fronts (they should be rotated anyway) and see what that does... But I'm trying to get ideas of what else to look for. Never have had an inconsistent shake before like this. Make sure your rims are hub centric. If they are not, you need to buy hub centric rings for them. Then have the wheels balanced again. Not every shop is good at balancing wheels. I have had mine done, and then went to a different shop to recheck them. The new shop told the that the guys at the other shop didn't know what they were doing. They re-balanced them, and I have had zero problems since. If all of these things check out and you are still having issues, then you probably have a bent rim. My wheels are not hub centric, but the previous owner put them with plastic rings? Have you or anyone else heard bad things about plastic rings? Should I get aluminum ones? QUOTE I centered the rears with my lug nuts though. Would it still cause vibration like that coming from the rear? You can't center with your lugs man, wtf. Go on ebay and buy some. Does the wobble come from the rear or it's clearly felt through the steering wheel? -------------------- |
Sep 18, 2013 - 12:49 PM |
Yes you can center wheels with the lugnuts
That's how I have to center the rims on my nova -------------------- 95 gt coupe, v6 swap weekend toy
Sep 18, 2013 - 1:04 PM |
Just wanna say I can't wait for this meet
Can't wait to meet everyone. Gonna get to meet a lot of people an see some cars I never thought I'd see in person Can't wait !!! -------------------- 95 gt coupe, v6 swap weekend toy
Sep 18, 2013 - 1:18 PM |
Screw you guys, why are you so far away from me...
Lo-Fi Version | Time is now: November 22nd, 2024 - 8:36 PM |
