> Removing the stainless factory exhaust tip
post Jul 13, 2013 - 2:18 PM
6thcelestial
Joined Dec 29, '08
From midwest
I am in the process of trying to replace the rear bumper reinforcment bar, but the bolt right above the exhaust tip is basically corroded on. I need to get the exhaust tip out of the way so I can get a better shot at the bolt. Would appreciate any help with this. Thanks.
post Jul 13, 2013 - 2:32 PM
The_enD
Joined Apr 12, '13
From Bulgaria
I broke 2 out of 5 of the bolts. The rust got to them. I used a ratchet for all except the one above the exhaust. I was able to remove it with a wrench and a lot of small turning actions cause it's very tight.
If you have no success with the wrench(too much rust) just cut the head. Get a hammer and something like a metal rod that has a head like a flat head screwdriver and hit it a couple of times.
FS thread : Custom Celica parts made to order + more
Click the image to visit my FB page
post Jul 15, 2013 - 5:22 PM
6thcelestial
Joined Dec 29, '08
From midwest
Okay thanks. How about getting the factory exhaust tip off?
This post has been edited by 6thcelestial: Jul 15, 2013 - 5:22 PM
post Jul 17, 2013 - 1:44 PM
it slides out of place, its not welded.
post Jul 18, 2013 - 7:36 AM
6thcelestial
Joined Dec 29, '08
From midwest
That's what I thought at first, but when I got close, it looks like it is welded at 2 spots on the pipe. I could be wrong, but that is what I see. I know it is the factory tip though.
post Jul 19, 2013 - 6:58 AM
mine slided out. all you can do is try.
post Jul 19, 2013 - 7:40 AM
6thcelestial
Joined Dec 29, '08
From midwest
What year was yours, and did you just get behind it with a rubber mallet to loosen it, or pull from the front? Appreciate the help.
Lo-Fi Version Time is now: December 2nd, 2024 - 1:35 PM
