> 2nd 3sgte engine tearing it down and putting it back together, the good the bad... the ugly?
post Jul 15, 2013 - 9:43 PM
garin
Joined Aug 12, '07
From Lancaster, Pa
so as manny and mr. thoma know i was getting a paint quote on sunday. on my way home my celica shut off and will not start again. timing belt is good. cams look fine. i have no compression in one cylinder. smells burnt im gonna guess bad pisons/rings until i pull it all apart. i am planning on pulling my engine out. i have another lomg block on a stand that i want to rebuild. i am curious as to what engine gasket overhaul kits are a go and which ones are... not so much. i work at a toyota dealership and i understand you get what you pay for, but dont really wanna take a mortgage out to rebuild an engine. couldn't find anything from beck arnley... just looking for thoughts on kits that are good. words of wisdom are welcomed too. please and thank you.
This post has been edited by garin: Jul 18, 2013 - 8:40 PM
post Jul 16, 2013 - 5:20 AM
dont go aftermarket.
oem is the way to go for a gasket kit.
post Jul 16, 2013 - 10:54 AM
garin
Joined Aug 12, '07
From Lancaster, Pa
I'm grabbing my jdm vin plate and taking it in tomorrow. Oem is looking like the answer.
Beck arnley used to do oem strapped gaskets back in the day...
post Jul 16, 2013 - 9:59 PM
Your jdm vin won't do you any good as microcat can't read jdm vins. Just tell the guys in your parts department to look under 90 Celica, and filter the chassis for ST185. All of the parts are the same as what came in the Celica Alltrac.
Sadly aftermarket gasket sets suck for Toyotas because they try to replace half the stuff with paper gaskets that fail after just a few months.
You probably don't need a whole gasket set besides the head gasket. Joe and I replaced most of the stuff with OEM gaskets. You should also be able to reuse the timing belt as its also OEM and was done by us just a few years ago.
This post has been edited by lagos: Jul 16, 2013 - 10:02 PM
post Jul 16, 2013 - 10:05 PM
garin
Joined Aug 12, '07
From Lancaster, Pa
i have another long block im gonna use. i figured the jdm vin would do much, but the parts guy at my dealership insists he have a vin.
post Jul 16, 2013 - 10:13 PM
He doesn't need the vin. I worked for over a year at a toyota parts department. Just tell him to filter by car and by chasis.
Sometimes you need a vin because 5 different versions of the same part will pop up, but thats not the case with the alltrac. Tell him to learn how to use microcat and stop being lazy.
This post has been edited by lagos: Jul 16, 2013 - 10:13 PM
post Jul 16, 2013 - 10:47 PM
Syaoran
Joined Jan 4, '12
From US
Hope my crappy paper gaskets don't take a **** in a few months
1993 Celica GT Coupe - sold
1994 Celica GT Liftback
post Jul 16, 2013 - 10:52 PM
QUOTE (Syaoran @ Jul 16, 2013 - 11:47 PM) *
They will. Especially the oil pan one.
post Jul 17, 2013 - 2:42 AM
Syaoran
Joined Jan 4, '12
From US
QUOTE (lagos @ Jul 16, 2013 - 11:52 PM) *
God help us all
post Jul 18, 2013 - 8:35 PM
garin
Joined Aug 12, '07
From Lancaster, Pa
i went with a toyota engine gasket kit, water pump, timing belt, and components. taking out the 1991 3sgte and putting in a 1993 3sgte.
Lo-Fi Version Time is now: November 29th, 2024 - 11:07 PM
