> No ignition, at all, No dashboard response, starter or ACC
post Jul 17, 2013 - 5:12 AM
PolliS_5S-FE
Joined Aug 29, '08
From Auckland, New Zealand
Hey guys, went to go home from work today, put key in the ignition, turned it, nothing, no radio, no dashboard lights, nothing.. Try to crank, its like I havent even touched the ignition, the key turns fine but its like the car is absolutely dead. No starter click nothing at all!
External lights work fine, inside lights, brake lights all that work sweet as.
Its almost like the car doesn't have a motor or any accessories connected to the ignition. Checked all fuses and they look fine. Ignition relay perhaps...? Where would I find this?
Thanks...
post Jul 17, 2013 - 5:16 AM
The_enD
Joined Apr 12, '13
From Bulgaria
Dead battery or starter?
FS thread : Custom Celica parts made to order + more
Click the image to visit my FB page
post Jul 17, 2013 - 11:24 AM
Syaoran
Joined Jan 4, '12
From US
Sounds like the battery has enough juice to power small things but not the big things.
That or there is a blown fuse somewhere.
1993 Celica GT Coupe - sold
1994 Celica GT Liftback
post Jul 17, 2013 - 11:40 AM
richee3
Joined Jun 29, '08
From Denver
Could be the EFI relay in the relay box under the hood. I had this exact problem once after I dropped my old 5S in my blue Celica. Turns out I was just missing my EFI relay.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Jul 17, 2013 - 3:57 PM
PolliS_5S-FE
Joined Aug 29, '08
Tried to jump the motor last nite too. Left it with jumper cables on for a good long AGES and still no signs of life at all. I have checked all of the fuses in the drivers side compartment and in the engine bay that I can think of and they seem to be fine.
EFI Relay, hmm would that cause no signs of life at all?
post Jul 17, 2013 - 5:21 PM
HistoriCo
Joined Jul 8, '13
From Norway
Check (and maybe replace) all the cables that are attached to your battery. It may be a bad connection or just to much corrosion for the battery to push the juice to the rest of the car.
I had that problem for about 2 months ago. Replaced the cables and the car starts wonderfully! ^^
post Jul 17, 2013 - 7:49 PM
PolliS_5S-FE
Joined Aug 29, '08
Its defo not the battery.
No corrosion at all, all the rest of the car has life, just not the ignition switch... dash...
post Jul 18, 2013 - 7:42 PM
PolliS_5S-FE
Joined Aug 29, '08
Turned out to be ignition switch fuse fault and wiring knackered. All fixed now
Lo-Fi Version Time is now: November 30th, 2024 - 12:04 AM
