> Wiring speakers to a 4 channel amp, just the door speakers and the rear speakers
post Jul 17, 2013 - 2:55 PM
secra12
Joined Apr 3, '13
From Statesboro or Leesburg Georgia
Once i get my tweeter covers in the mail, im going to be rewiring my speakers to a 4 channel amp. Has anybody else here done this? I already have my Kenwood wired to 2 12" kicker comps in my trunk with a bettery powering an audiopipe mini amp in my trunk (yes my car runs off 2 batteries-stops my headlights from dimming). I have an 8" speaker in each door(idk the make/model as i got them from a friend that moved recently)and he also spliced in tweeters from the speakers. In the rear i have 2 sony explods installed (not sure of the size b/c the previous owner had them installed).
This will be my first attempt at wiring speakers and i have no clue really what im doing. Can anybody help?
I have already bought 16 gauge speaker wire and another set of rca cables. All will be wired to an older 4 channel Sony amp until i can afford a newer one.
Auto 94 ST COUPE w/ 225k miles
Best cars ehvah
post Jul 17, 2013 - 5:31 PM
The_enD
Joined Apr 12, '13
From Bulgaria
In reality, what is your question?
You secure the amp, run it's power, source, wires to each speaker and set the settings. Done.
This post has been edited by The_enD: Jul 17, 2013 - 5:31 PM
FS thread : Custom Celica parts made to order + more
Click the image to visit my FB page
post Jul 17, 2013 - 5:37 PM
secra12
Joined Apr 3, '13
QUOTE (The_enD @ Jul 17, 2013 - 6:31 PM) *
I do not know exactly how to get it wired though. I can run wires from the amp but as far as wiring the speaker into the amp idk. Would i splice the amp into the speaker wire? And as far as the rcas, they just get plugged into the back of my stereo right?
Best cars ehvah
post Jul 17, 2013 - 5:47 PM
The_enD
Joined Apr 12, '13
From Bulgaria
The amp has 4 channels to which you connect each of the 4 speakers.
And yes, the RCAs are plugged in the back of the HU/stereo.
Like this, but with tweeters and midbass or whatever you have. Be sure to distinguish left and right channels.
post Jul 17, 2013 - 5:50 PM
secra12
Joined Apr 3, '13
QUOTE (The_enD @ Jul 17, 2013 - 6:47 PM) *
So i do not splice the speakers into wires ran from the amp, i just cut the wires running from the speaker to the stereo and connect them to the new wires? Sorry, im a noob at this
Best cars ehvah
post Jul 17, 2013 - 6:03 PM
The_enD
Joined Apr 12, '13
From Bulgaria
Yes, you cut the already existing wires and connect to the ones you run from the amp.
If you splice the wire, the speakers will receive signal from both the stereo and the amp which is not good.
Use solder and heatshrink for some good outcome.
post Jul 17, 2013 - 6:05 PM
secra12
Joined Apr 3, '13
QUOTE (The_enD @ Jul 17, 2013 - 7:03 PM) *
Thanks! Oh what wires do I need to cut?
Best cars ehvah
post Jul 17, 2013 - 6:16 PM
The_enD
Joined Apr 12, '13
From Bulgaria
Well, there is the problem, you actually have only one set of speaker wire in the door if I am reading correctly. And you need 2 sets, one for the 8 and the tweeter. And it's very hard to run new wires through the door and it's rubber jacket. But that is what you will have to do.
I am in the chat, find me there.
post Jul 17, 2013 - 9:36 PM
secra12
Joined Apr 3, '13
QUOTE (The_enD @ Jul 17, 2013 - 7:16 PM) *
My friend spliced the tweeters into the door speakers. So would i only need one set of wires rewired? I think im getting the general idea of what to do
Best cars ehvah
post Jul 18, 2013 - 5:31 AM
The_enD
Joined Apr 12, '13
From Bulgaria
Imagine sub 1 and 2 are the tweeter and the 8.
Two red and two blue wires from the amp have to go through the door and it's rubber jacket that is right next to the hinges.
But you already have two wires run factory, so locate were they are in your footwell or somewhere and cut them, then connect one set of wires that comes from the amp.
You get my point?
post Jul 18, 2013 - 7:17 AM
secra12
Joined Apr 3, '13
QUOTE (The_enD @ Jul 18, 2013 - 6:31 AM) *
You get my point?
Gotya. Thanks
Best cars ehvah
post Jul 18, 2013 - 7:51 AM
The_enD
Joined Apr 12, '13
From Bulgaria
One way that comes to minds that you can try to put the wires through the jacket.
Find the factory wire that is now attached to your 8. Cut it on the side that is in the car and to that end connect the new four wires very securely. Then start pulling from the inside of the door so it goes all the way through and you see the 4 new wires.
post Jul 18, 2013 - 12:31 PM
secra12
Joined Apr 3, '13
QUOTE (The_enD @ Jul 18, 2013 - 7:51 AM) *
Good idea thanks
Oh and since the tweeters are spliced into the speaker wire, i unsplice it, and run the tweeter directly to the amp?
This post has been edited by secra12: Jul 18, 2013 - 12:33 PM
Best cars ehvah
post Jul 18, 2013 - 12:52 PM
The_enD
Joined Apr 12, '13
From Bulgaria
Yep.
post Jul 18, 2013 - 12:53 PM
secra12
Joined Apr 3, '13
QUOTE (The_enD @ Jul 18, 2013 - 12:52 PM) *
Yep.
Cool
Best cars ehvah
post Jul 19, 2013 - 12:13 PM
nsxtypeR
Joined Jan 3, '06
From The Netherlands
Tweeter directly to the amp?? Byebye tweeter very soon I guess...
Just run 1 set of wires to each door and attach them to the filters that came with your tweeters. Your then attach your 'normal doorspeakers to that filter as well. Those filters will remove the high frequencies from your doorspeaker and pass themto the tweeters. They also prevent low frequencies (low and mid-bass) to go to your tweeters
JDM ST205
post Jul 19, 2013 - 12:16 PM
secra12
Joined Apr 3, '13
QUOTE (nsxtypeR @ Jul 19, 2013 - 12:13 PM) *
I currently have the oem tweeters hooked up. So no filter...
Best cars ehvah
post Jul 19, 2013 - 12:19 PM
nsxtypeR
Joined Jan 3, '06
I guess the oem's have a filter inside the oem amplifier then. You can buy these filters seperatly
JDM ST205
post Jul 19, 2013 - 12:21 PM
secra12
Joined Apr 3, '13
QUOTE (nsxtypeR @ Jul 19, 2013 - 12:19 PM) *
Lol i dont jave the oem amp either.
How much are these filters?
Best cars ehvah
post Jul 19, 2013 - 12:26 PM
nsxtypeR
Joined Jan 3, '06
Those shouldnt be expensive. Cant tell you how much they cost in your par of the world though. Google is your best friend
Edit: found them online for about €20 which equals about $27
This post has been edited by nsxtypeR: Jul 19, 2013 - 12:30 PM
JDM ST205
Lo-Fi Version Time is now: February 21st, 2025 - 7:37 AM
