![]() Enthusiast ![]() ![]() ![]() ![]() Joined Apr 12, '13 From Bulgaria Currently Offline Reputation: 53 (100%) ![]() |
The amplifier has build-in filters, I don't know why you suggest he buys that...
![]() Enthusiast ![]() Joined Apr 3, '13 From Statesboro or Leesburg Georgia Currently Offline Reputation: 3 (100%) ![]() |
Those shouldnt be expensive. Cant tell you how much they cost in your par of the world though. Google is your best friend Edit: found them online for about €20 which equals about $27 Alright thanks -------------------- Auto 94 ST COUPE w/ 225k miles
Best cars ehvah |
![]() Enthusiast ![]() ![]() Joined Jan 3, '06 From The Netherlands Currently Offline Reputation: 6 (100%) ![]() |
The amplifier has build-in filters, I don't know why you suggest he buys that... The amplifier doesn't filter out high frequencies only. If you connect a tweeter directly to the amplifier, it will burn out soon enough cuz its not build to handle low and mid-range frequencies. -------------------- JDM ST205
The amplifier has build-in filters, I don't know why you suggest he buys that... The amplifier doesn't filter out high frequencies only. If you connect a tweeter directly to the amplifier, it will burn out soon enough cuz its not build to handle low and mid-range frequencies. As I said, the amplifier has filters and you are wrong. It will filter all of the frequency range depending on your setting and the speakers you are going to connecting. -------------------- |
secra12 , post a picture of the available setting on your amp.
secra12 , post a picture of the available setting on your amp. Cant post picture right now but i kniw it has hdp, lpf, bass. Its an older Sony amp. -------------------- Auto 94 ST COUPE w/ 225k miles
Best cars ehvah |
The amplifier has build-in filters, I don't know why you suggest he buys that... The amplifier doesn't filter out high frequencies only. If you connect a tweeter directly to the amplifier, it will burn out soon enough cuz its not build to handle low and mid-range frequencies. As I said, the amplifier has filters and you are wrong. It will filter all of the frequency range depending on your setting and the speakers you are going to connecting. Even if the amp has the filters, ts already has 4 speakers he want to connect. In that case he doesnt have the terminals left to even connect them to the amp. Connecting tweeters directly to any amp is a waste of channels and your tweeters will die real soon. If you want to take that risk, be my guest but I'd rather spend 30 bucks and do it the right way -------------------- JDM ST205
Lo-Fi Version | Time is now: February 21st, 2025 - 9:31 AM |
