10 Pages V  « < 4 5 6 7 8 > »
> The GT-Four Brake Upgrade, ST205 Brake Upgrade for 5x100 & 5x114 PCB
post Apr 26, 2015 - 4:30 PM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
haha, thanks manny, there is still alot more information that needs to be added and organized, but we have all put it on pause since it driving season haha. I know Fate paused his brake and 5x114 swap for the summer.
エキサイティングカーレーシングチーム!
post Apr 27, 2015 - 1:37 AM
easternpiro1
Joined Feb 1, '05
From Charlotte NC
I'm surprised no one mentioned the cadillac catera (2001) and just redrilling those to 5x100. I was told that would work as well
This post has been edited by easternpiro1: Apr 27, 2015 - 1:38 AM
post Apr 27, 2015 - 7:24 AM
bsamps4
Joined May 16, '10
From Raleigh
I'm using the Cadillac Catera rotors, but I've been interested in test fitting Subaru BRZ rotors.
post Apr 28, 2015 - 12:27 PM
easternpiro1
Joined Feb 1, '05
From Charlotte NC
QUOTE (bsamps4 @ Apr 27, 2015 - 8:24 AM) *
They fit right on but are kind of skinny from what I've been told
post Apr 29, 2015 - 3:38 PM
QUOTE (njccmd2002 @ Mar 19, 2015 - 2:27 PM) *
Ok. To add more fuel to drama. I have found rotors very close to spec. For the scion frs. I have been looking on phone so i may have missed some stuff.
http://www.fr-sforum.com/forums/targa-newf...920/topics/8058
Some pics to summariZe
It comes as a kit. Wonder if rotors can be sold
This is where i get lost.
It states 299 mm with 32 mm diameter and 5x100.
Wonder if sold separately and if they are centered for the gt4 caliper
I think i found the hat needed for the job. Wilwood part 170- 8324. May have right offset or very close to needed.
post Apr 30, 2015 - 7:48 PM
Fate
Joined Nov 30, '04
From Atlantic City
QUOTE (njccmd2002 @ Apr 29, 2015 - 4:38 PM) *
Tell me more!
post Apr 30, 2015 - 8:09 PM
I will. I need to re do my calcs sgain
post May 1, 2015 - 8:03 AM
The gt4 rotor has a hat height of 1.129 inches. To that substract a small recess portion of 0.048 and the face thickness of 0.249. You get aprox offset of 0.832 inches .
0.77 inches of offset is close to that and might even pull away disc little away from ball joint. Im waiting on Mike to measure the supra hat. But again, im not 100 positive. But this hat is already 5x 100. Application. Hub may be a little wide. Not by much. Maybe 0.141 inches
post May 1, 2015 - 9:28 AM
olilaroche
Joined Feb 21, '14
From l'assomption, Québec
is there anybody who already uses the rear st205 calipers that can unscrew 1 bolt to measure it? I'm stuck a this point! i know it's slightly longer than the st204 gay caliper, but i don't know by how long!
post May 1, 2015 - 3:10 PM
QUOTE (olilaroche @ May 1, 2015 - 9:28 AM) *
Get one and cut to lenght. You will need to use washers
post May 1, 2015 - 8:16 PM
Fate
Joined Nov 30, '04
From Atlantic City
QUOTE (njccmd2002 @ May 1, 2015 - 9:03 AM) *
Very interesting.
EDIT: My only concern that matching the gt4 rotor specs would still require shaving of the caliper's mounting points.
This post has been edited by Fate: May 1, 2015 - 8:21 PM
post May 1, 2015 - 10:47 PM
There is always a tradeoff. Always. You can always look for a 30 mm disc. Its never going to be perfect.
post May 2, 2015 - 7:34 AM
MGCustoms325
Joined Feb 28, '08
From Miramar, Florida
I'll do you one better. Here is the Toyota part # 90105-08317. You will need 4
post May 2, 2015 - 7:38 AM
olilaroche
Joined Feb 21, '14
[/quote]
that's the best news of my day! thank you so much!😀
I'll soon be able to install everything on the car... one step closer to get it back on the road!
post May 2, 2015 - 3:11 PM
mi645
Joined May 23, '12
From northridge,CA
After i installed my rear gt4 brake kit. I get intense squeals... Its intermenit but my foot is not even on the brakes. Im using gt4 wrc pads and rear supra brake pad shims. Didnt fit quite perfectly. Gonna take it apart and see whats going on. And got 2 washers on the rear to space the brake caliper 5mm away from the hub
post May 4, 2015 - 12:23 AM
olilaroche
Joined Feb 21, '14
QUOTE (mi645 @ May 2, 2015 - 3:11 PM) *
have you found your rear brake problem ?
post Jun 9, 2015 - 9:54 PM
Arturio55
Joined Mar 6, '13
From New jersey
QUOTE (felipeandrest205 @ Mar 16, 2015 - 11:06 PM) *
For the rear brake rotors, I was looking at the WRX (G3) up to 2007, there are some difference from the height, but maybe can do something
DBA 2663 WRX
Specifications
Diameter 290
Height 64
Thickness 18
Min Thickness 16
C/Hole 58
Bolt holes 5 X 100 PCD
CELICA
Vent Vented
Diameter 315
Height 59
Thickness 16
Min Thickness 15
Centre Hole Dia 55
Bolt Holes 5
There are just 5mm of difference on the height and a minor difference on the thicknes. Anyone has tested this?
WRX from 2009 and up, rear brake rotors have a 64mm of height vs 59mm of the Celica ones, maybe there could be an option
Can someone check to see if this will work? Seems pretty legit
QUOTE (Azncelica @ Mar 4, 2012 - 11:43 PM) *
I started with what I know to do, I swap engine into my car, I knew it was too much work to make it a AWD. I kept it FWD. Went to take a crack at doing the wiring conversion. Than, I realize, shoot, this is out of my league.
post Aug 1, 2015 - 1:37 AM
felipeandrest205
Joined Dec 14, '14
From Chile
Have another brake disc mates
Its from a Subaru Liberty/Legacy
DBA makes them and a lot of other manufacturers
post Aug 3, 2015 - 8:45 PM
will test my theory, and ordered parts for the right disc today. 333 USD crossing fingers
post Aug 4, 2015 - 9:42 PM
Hahaha. No interest. Thats ok..
12 User(s) are reading this topic (12 Guests and 0 Anonymous Users)
Lo-Fi Version Time is now: November 23rd, 2024 - 9:16 AM
