> NEED HELP WITH THE ST205, trouble going into gear
post Jul 29, 2013 - 12:26 PM
hzawde
Joined Nov 13, '10
From Calgary
so my car has been perfect for a good amount of time now. all of a sudden last night it had trouble going into first gear,
and every gear after that was also a bit tough. this morning i tried it makes a noise when i try to go into any gear but with force it will go.
what is going on?? my clutch is fine i believe, this all happened so sudden. any help is appreciated, i love my gt four frown.gif
post Jul 29, 2013 - 12:31 PM
hzawde
Joined Nov 13, '10
From Calgary
it shifts well if the car is not on , also.
post Jul 29, 2013 - 12:35 PM
bsamps4
Joined May 16, '10
From Raleigh
Have you pulled the tranny down to look for your problem yet?
post Jul 29, 2013 - 1:15 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
you broke a spring on the clutch disk.
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Jul 29, 2013 - 1:25 PM
hzawde
Joined Nov 13, '10
From Calgary
QUOTE (Smaay @ Jul 29, 2013 - 1:15 PM) *
for sure ? i was thinking their was just a leak somewhere and air got in
post Jul 29, 2013 - 3:16 PM
ZoomZoom
Joined Apr 7, '04
From Toronto
check your shifter cables
post Jul 29, 2013 - 3:47 PM
azian_advanced
Joined Apr 18, '05
From Calgary
x2 on the shifter cables. they could be starting to seize.
post Jul 29, 2013 - 4:28 PM
delusionz
Joined Feb 11, '08
From Auckland, New Zealand
master cyl or pushrod?? clutch not fully disengaging?
Mike W
269awhp / 273ft-lbs
post Jul 31, 2013 - 10:28 AM
hzawde
Joined Nov 13, '10
From Calgary
I'll check the shifter cables tonight, I was thinking master cylinder or slave. But one shop said its the clutch for sure and they wanna charge me 1900 for it
post Jul 31, 2013 - 11:27 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
1900 to change a clutch on an ST205 is a little steep, but its not an easy job. you pretty much have to pull the entire engine out
Lo-Fi Version Time is now: November 30th, 2024 - 2:17 AM
