Thank god for triple a. (assuming no spark) |
Jul 30, 2013 - 7:34 PM |
Enthusiast Joined Apr 10, '12 From Chicago Currently Offline Reputation: 0 (0%) |
Wellp ironically I was driving to my college to apply for my classes today and I decided to take some mechanic classes. Anyways while driving my car just lost all power. I tried to start the car and all I heard was the starter trying to start the engine and I heard the fuel pump engage as well. I get my car towed home in my garage pop the hood my intake stank of raw fuel as well did the spark plugs. Right off the bat I'm going to assume its the ignition coil since it probably hasnt been changed ever considering my cars sketchy past. Only proof of work done I got with it was a timing belt being done. The coil is only 35$ at Oreillys Im just stuck at home waiting for a ride with my friend when he gets off work.
Ive read numerous threads on here today that have sounded EXACTLY like what happened to me today so I'm dead set on the ignition coil as my first move. http://www.6gc.net/forums/index.php?showtopic=88244 http://www.6gc.net/forums/index.php?showtopic=89485 One level headed the other well filled with panic like I was before using search lol Anyways does anyone have any other theories just in case this doesn't solve my problem? (94 celica gt 5sfe automatic) This post has been edited by SiriusVirus: Jul 30, 2013 - 7:38 PM |
Jul 30, 2013 - 8:27 PM |
Take off the distributor cap and make sure there isn't spaghetti in it. If that checks out I'd look into the coil.
Jul 30, 2013 - 9:06 PM |
Enthusiast Joined Oct 11, '11 From Chattanooga Currently Offline Reputation: 0 (0%) |
This happened to me. It was my ignitor.
Jul 30, 2013 - 9:13 PM |
Im glad I'm not the only person this is happening to lol.
Jul 30, 2013 - 9:16 PM |
Lol, yeah same. And mine is a 94 GT auto 5sfe. I got 130,000 on the old girl. She's just starting to have all kinds of electrical issues for some reason. I guess she's just getting old. Poor girl.
Jul 31, 2013 - 1:00 AM |
So I did the ignition coil car cranks and still doesnt turn over. In fact it shot fire out the intake. My engine is flooded with gas and wont run how do I go about this
Jul 31, 2013 - 1:02 AM |
Pull the spark plugs and twist up some paper towels to shove in and absorb any fuel sitting on top of the pistons. Let it sit overnight with the plugs out to evaporate.
Jul 31, 2013 - 1:04 AM |
Do you think it will run? All my friends now think its the starter..?
Jul 31, 2013 - 1:22 AM |
Once you get all the excess fuel out we'll know. If the car is turning over incredibly slow, then perhaps the starter. If it still turns over normally it's something else.
Jul 31, 2013 - 1:25 AM |
the turning over sounded ridiculously fast. I guess I'll get back to you tomorrow morning fingers crossed on this one.
Jul 31, 2013 - 1:39 AM |
That being the case the starter is fine then. If it's noticeably faster than what it used to be that sounds like a loss of compression.
Jul 31, 2013 - 1:41 AM |
After the first fire ball it sounded more and more normal until I said **** it lets push it out of my garage to the front of my house for the night. only cranked it 3 times though
This post has been edited by SiriusVirus: Jul 31, 2013 - 1:43 AM |
Jul 31, 2013 - 1:55 AM |
I say just let the fuel evaporate overnight and try it again later.
Jul 31, 2013 - 3:39 AM |
Enthusiast Joined Jun 2, '10 From Davenport, Florida Currently Offline Reputation: 0 (0%) |
if its cranking overly fast you may have snapped your timing belt, if the valves are open there's no compression and the crank will free spin. It would also explain why you got a fireball through the intake, the intake valve is open and the stroke pushed the gas up through the intake as it ignited. take the top couple of bolts to the top timing cover off and pull it away from the head. if the belt is off it will be immediately apparent
This post has been edited by b22ri22an: Jul 31, 2013 - 3:41 AM -------------------- |
Jul 31, 2013 - 1:00 PM |
I'll look into the timing belt soon I have to start getting for work http://www.youtube.com/watch?v=5gmJnx3usLM...eature=youtu.be the video is my car and what it sounds like.
This post has been edited by SiriusVirus: Jul 31, 2013 - 1:04 PM |
Jul 31, 2013 - 6:24 PM |
two things will make it sound like that, snapped timing belt or bad bendix drive in the starter..... look at the crank pulley while someone hits the ignition if it spins you need a timing belt. if it doesn't you need a starter
Jul 31, 2013 - 9:51 PM |
I'm going to throw my vote in for timing. If it were a 5-speed you could test to see if it's the starter or not. Would be easier to check timing than to remove the starter to have it tested.
This post has been edited by Box: Jul 31, 2013 - 9:51 PM -------------------- 2001 Miata LS 5-speed
Aug 1, 2013 - 3:27 AM |
Chicago has been absolute garbage weather raining nonstop. Just about everyone seems to think its the bendix drive mechanic friends just based off the sound say it because theyve expeirienced the problem. They didnt even consider timing belt until I shot the question if that could be it. But I mean I think I have less than 20k on the belt I dont have the paper work that came with my car when I bought it but I know it got changed before I bought the car.
Aug 1, 2013 - 4:24 AM |
It takes like 10 minutes to check the belt though. The starter going out wouldn't cause the car to die while driving, which was the initial problem.
Aug 1, 2013 - 7:59 AM |
box is right... bendix drive won't stop a running engine
it can be easily ruled out though, have a friend turn the ignition while you look under the hood at the crank pulley, if the crank pulley spins your bendix drive is engaging fine and you need to check your timing belt. if it doesn't spin then your starter isn't engaging the flywheel and needs to be replaced. from the above comments about the motor dying while driving, and the fireball while trying to start the car I would bet money on the timing belt -------------------- |
Lo-Fi Version | Time is now: November 29th, 2024 - 5:54 PM |
