> Wiring internal LED lights
post Jul 31, 2013 - 1:40 PM
marblesmike
Joined Jul 8, '13
From NJ
Hey folks,
I'm planning on adding some interior LED lighting. I'm thinking of starting off with the footwell area. I'd preferably like the lights to only go on when my headlights go on. Any suggestions on where to wire the lights? I know I could wire them behind the cig lighter but then they'd be on always. Any suggestions? Thanks!
post Jul 31, 2013 - 4:15 PM
The_enD
Joined Apr 12, '13
From Bulgaria
QUOTE (marblesmike @ Jul 31, 2013 - 9:40 PM) *
Hey folks,
Headlights or parking lights, to be clear?
FS thread : Custom Celica parts made to order + more
Click the image to visit my FB page
post Jul 31, 2013 - 6:19 PM
JoshuaM
Joined Mar 6, '12
From Brisbane, Australia
Any reason why you want that? Wouldn't it be more usable to have then turn on when the doors opened? Just having them on when you are driving would probably get a little distracting at night.
If you did want to do it that way, I know the CD player has an input to dim the lights when the headlights are turned on. You could run power from the cig. lighter and with a transistor acting as an automatic switch on that stereo input wire. That would mean they would come on when both the lights are on, and the car is on (or in acc.)
This post has been edited by JoshuaM: Jul 31, 2013 - 6:22 PM
post Aug 1, 2013 - 10:04 AM
rentaspace
Joined Sep 23, '12
From Australia
I got mine linked to a double pole switch, on side is positive to a constant 12v and the other goes to the kick panel relay box and taps into the positive door light wire. This way I have full control over the LEDs. I can have them on when the door opens and off when the cops pull me over or on constantly for showing off like a dick hahaha
The switch cost like $2 as well, only difference is that it has up and down tongue.gif
Just remember to use the positives to the outer connections and the single ground to the centre connection on the switch or you will have them on when you don't want and off when you do tongue.gif
This post has been edited by rentaspace: Aug 1, 2013 - 10:04 AM
post Aug 5, 2013 - 11:32 AM
marblesmike
Joined Jul 8, '13
From NJ
Okay, so what I ended up doing was getting one of those adapters at Pep Boys that has 6 wire terminals with switches and a 12v car adapter plug. I snipped off the plug and wired it to the back of the cigarette lighter. Then put 9 inch led strips in both footwells and 3 inch led strips behind the two center vents. I'd like to remount the ones in the vents because now I can clearly see the LED strip when lit and I'd like it to be a bit more ambient. Other than that though it looks great and I can switch the lights on/off whenever I'd like to.
post Aug 11, 2013 - 8:13 AM
rentaspace
Joined Sep 23, '12
From Australia
QUOTE (marblesmike @ Aug 5, 2013 - 11:32 AM) *
post Aug 17, 2013 - 9:49 AM
marblesmike
Joined Jul 8, '13
From NJ
QUOTE (rentaspace @ Aug 11, 2013 - 9:13 AM) *
Haven't gotten around to it yet, but I've installing new speakers today so maybe I'll redo the lights too. Anyone here have any suggestions for mounting LEDs in the vents and where to place them?
Lo-Fi Version Time is now: February 23rd, 2025 - 12:00 AM
