replacing clutch master cylinder, on st205 |
Aug 1, 2013 - 6:02 PM |
Enthusiast Joined Nov 13, '10 From Calgary Currently Offline Reputation: 0 (0%) |
my mechanic told me that the 205 and 202 models both use the same master cylinder.
when i received it, it looks like the neck on the 202 is longer than the 205, but when i placed it against the car it looks like it can still fit, it will just be a tight fit. Am i correct or will it not fit? my other solution is to just cut the neck/funnel in half so its the same size as the stubby 205 one. |
Aug 1, 2013 - 6:14 PM |
Hmm. Since I'm fairly sure the floor pan doesn't differ in that section, that means pedal placement doesn't differ, so therefore the mounting point for the master cylinder can't differ either.
'93 MX-5 LE |
Aug 1, 2013 - 6:30 PM |
Hmm. Since I'm fairly sure the floor pan doesn't differ in that section, that means pedal placement doesn't differ, so therefore the mounting point for the master cylinder can't differ either. the mounting position is exactly the same, the issue is where the fluid goes in, its longer and looks like it might not fit |
Lo-Fi Version | Time is now: December 2nd, 2024 - 4:55 AM |
