Help, Cars sputtering |
Aug 2, 2013 - 11:33 AM |
Enthusiast Joined Apr 17, '13 From Beaufort, SC Currently Offline Reputation: 0 (0%) |
Well heres the low down.... I have a 94 Celica GT. About 2 months ago it starting giving me trouble with starting up. Usually it would be after work on a hot day and when I was low on gas. In the morning it would crank up fine. So I replaced the Fuel Filter. Seemed to work fine for a while, then the trouble would start up again. So I went to the Fuel Pump and changed that out. Now it starts up fine but its jerking like a misfire (changed the spark plugs about 4 months ago so I know its not that) when I drive it and actually made the check engine light come on. Questions: Could it be the strainer on the fuel pump as I put the old one back on the new Pump? The bad fuel pump/filter might have made the injectors go bad?? Or is this a new problem??
Aug 2, 2013 - 2:01 PM |
http://www.6gc.net/howto/determine_check_engine_light_codes
Find out what the code is. I'm thinking perhaps a bad MAP sensor. -------------------- 2001 Miata LS 5-speed
Lo-Fi Version | Time is now: December 4th, 2024 - 11:20 AM |
