P0401 issue :(, Somebody has fixed this problem?? |
Aug 5, 2013 - 2:08 AM |
Enthusiast Joined Jul 15, '07 From Mexico Currently Offline Reputation: 2 (100%) |
I saw a lot of posts about the p0401 code, but i canīt find somebody wich fix this code. i already did all this changes to my car.
i changed the next list: spark plugs wires spark plugs distributor cap and rotor head gasket fuel pump fuel filter. MAP sensor cleaned: EGR valve IAC valve checked all egr vacumm lines and i have same problem, same p0401 code, my car its on very slow rpms it shakes on any speed (10, 30, 60 MPH) and i have no idea what else to check to fix this problem ... did someone else having this problem and got fixed?? thank you!! |
Aug 7, 2013 - 4:06 AM |
Enthusiast Joined Mar 8, '12 From Hanford/Fresno, Ca Currently Offline Reputation: 20 (100%) |
I'd start with mild stuff like run premium gas AKA 91 for NA or run 93 for turbod. I'd recommend running on high quality gas. I run 89octance Chevron gas in my lil 5sfe daily. Run like that for a week and see if there's any difference. If not then use Lucas Fuel Treatment or the Sea Foam.
Aug 7, 2013 - 5:09 AM |
Btw, you meant the engine would shake like as in it would stutter like its about to stall?
Aug 7, 2013 - 1:00 PM |
It's an EGR code, which means it'll be one of four things: EGR valve, EGR modulator, EGR solenoid, or EGR temperature sensor. The solenoid and temp sensor can be tested with a multi-meter. When you cleaned the EGR valve did you also clean the tube? Usually the tube will get clogged up causing the problem.
Here's how to test for the 7A-FE, it's close enough to the 5S to give you a better idea on what to do though: http://ww2.justanswer.com/uploads/skyvisio...44_95_rolla.pdf -------------------- 2001 Miata LS 5-speed
Aug 10, 2013 - 1:48 PM |
Aug 10, 2013 - 1:51 PM |
It's an EGR code, which means it'll be one of four things: EGR valve, EGR modulator, EGR solenoid, or EGR temperature sensor. The solenoid and temp sensor can be tested with a multi-meter. When you cleaned the EGR valve did you also clean the tube? Usually the tube will get clogged up causing the problem. Here's how to test for the 7A-FE, it's close enough to the 5S to give you a better idea on what to do though: http://ww2.justanswer.com/uploads/skyvisio...44_95_rolla.pdf i had cleanded the tube but with the valve out of engine. let me check this link. thank you a lot guys! |
Aug 11, 2013 - 10:50 AM |
Usually the modulator has failed, the diaphragm inside is torn and the modulator must be replaced.
Aug 11, 2013 - 2:15 PM |
Usually the modulator has failed, the diaphragm inside is torn and the modulator must be replaced. That, what ended up happening to mine after running through all of the tests. -------------------- 2001 Miata LS 5-speed
Lo-Fi Version | Time is now: November 23rd, 2024 - 9:56 AM |
