> 1mzfe swap, ST Model
post Aug 13, 2013 - 1:13 PM
CrossCudi
Joined Mar 10, '11
From New Jersey
so i pulled this up from 2007' i know prolly
alot more swaps has been done since.
QUOTE (My2Celi @ Jun 4, 2007 - 12:25 AM) *
My input would be
You need:
Motor: 3vzfe, 4vzfe, 5vzfe, 1mzfe, 3mzfe
Transmission: V6 Camry, V6 Solora, Turbo Mr2, ES300 (E153 or auto)
Motor mounts: altrac mounts on all side except for front GT motor mount ill work, passenger side will need to have an adapter plate
ECU: best to use a Camry, Solara, or ES300 ECU or use a EMS
Engine harness
Misc: Custom Y pipe as said already on the thread, metal HG for 3vz users,
Axle: ??? <-- havent got there yet.
I know i'm missing more stuff but I will keep updated with my project.
i am interested in the 1mz, and i have an ST.
so i will need, the 1mz * which year and from which car is my best option, e153 from any GT 6gc ?, motor mounts ?? a little lost with this one, v6 camry ECU, axle...????
my current motor is shot i need a swap ASAP, i must get to this RI meet... kindasad.gif
94' Celica GT Manual
post Aug 13, 2013 - 1:30 PM
Box
Joined Feb 23, '12
From Warrior, AL
You'll want a pre drive by wire model, so around 2003 or earlier. Can source them from a Camry/Solara, ES300, Sienna, or Avalon. The real joy comes in finding a manual Camry/Solara, which they have the E153 along with the ECU set for a manual. The 6GC GT has the S54, which could also be used. Being it's a ST you'll need the trans mount and front engine mount at least. I can't remember which axles were used, but I want to say one of them was from a MR2? Don't hold me to that one. The best thing to do would be to find a Camry/Solara with the V6 and E153 that's been wrecked and use it as a donor.
This post has been edited by Box: Aug 13, 2013 - 1:31 PM
2001 Miata LS 5-speed
post Aug 13, 2013 - 2:48 PM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
There are a few swap/build threads on this site regarding the 1MZ/3MZ motor. I think you will find all of the needed information within those threads.
**** Photobucket
post Aug 13, 2013 - 4:14 PM
CrossCudi
Joined Mar 10, '11
From New Jersey
QUOTE (Box @ Aug 13, 2013 - 2:30 PM) *
QUOTE (95CelicaST @ Aug 13, 2013 - 3:48 PM) *
Searched already !!
post Aug 13, 2013 - 4:52 PM
kurt95gt
Joined Aug 23, '11
From kenton ohio
You must not of searched too hard my swap is on the first page of my projects an has 1mz right in the name lol
Do you have emissions to worry about??
94 st hatch my daily driver
n
post Aug 13, 2013 - 5:38 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
My swap thread is right below Kurts. both our threads have all the information you need.
If you use S54 trans, use MR2 non turbo axles.
if you use E153, you need a hybrid axle, MR2 Turbo inners and ST185 outters
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Aug 13, 2013 - 7:06 PM
CrossCudi
Joined Mar 10, '11
From New Jersey
QUOTE (kurt95gt @ Aug 13, 2013 - 5:52 PM) *
Thanks, no I don't need to worry about emissions..
QUOTE (Smaay @ Aug 13, 2013 - 6:38 PM) *
ok, sounds good.
sorry but I did a lot of research, trust me I have read both of u guys threads over n over,
but buying parts you wont need is a bad waste, so sorry for asking question we have already answers for on here.
post Aug 13, 2013 - 7:18 PM
CrossCudi
Joined Mar 10, '11
From New Jersey
will a manual trans from a solara on a 2azfe work ?
post Aug 13, 2013 - 7:42 PM
kurt95gt
Joined Aug 23, '11
From kenton ohio
OK you gonna want to get a 97+ 1mz
A 94-96 1mz lower intake with the injectors an fuel rail
A 97 Camry ecu (gotta dig up the part number)
You can use a s54 or a e153 tran those are the only fwd options
I used stock celica gt axles
n
post Aug 13, 2013 - 7:50 PM
CrossCudi
Joined Mar 10, '11
From New Jersey
are the gt axels an option for the ST ?
post Aug 13, 2013 - 11:57 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
QUOTE (CrossCudi @ Aug 13, 2013 - 5:18 PM) *
no different bolt patttern
QUOTE (CrossCudi @ Aug 13, 2013 - 5:50 PM) *
not sure what you are asking here
post Aug 14, 2013 - 12:07 AM
kurt95gt
Joined Aug 23, '11
From kenton ohio
Your going to need the front rear an drivers side stock motor mounts for a gt if you want to run a s54 an yes the gt axles will fit the st
n
post Aug 14, 2013 - 10:37 AM
CrossCudi
Joined Mar 10, '11
From New Jersey
wow this is soooo much easier for someone with a GT ...
post Aug 14, 2013 - 10:53 AM
kurt95gt
Joined Aug 23, '11
From kenton ohio
Yep
n
post Aug 14, 2013 - 3:35 PM
Box
Joined Feb 23, '12
From Warrior, AL
Just find a GT with a blown engine and go from there. Drive the ST until the GT is done, then you can swap anything you'd like to keep over and sell the ST.
post Aug 14, 2013 - 5:30 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
unfortunately Amy's car got smashed. It was an ST and I was about to do a V6 swap on it. I was going to Produce an Engine mount kit with all 4 engine mounts. No drilling required.
post Aug 14, 2013 - 5:48 PM
mkernz22
Joined May 10, '10
From MA
Also, find a 1mz-fe ecu from a 1997 Camry. You can actually swap it between Auto or Manual so that you don't have to deal with the engine codes.
Source:
http://www.mr2.com/forums/v6-owners-group/...p-progress.html
"There are no A/T solenoid codes to deal with IF you use a 1997 Camry 1MZ ECU. There's an adjustment ground built into the Camry ECUs that allow it to be changed from A/T to M/T, and vice-versa. The ground is not present in Avalon, Sienna, etc. ECUs."
post Aug 14, 2013 - 5:57 PM
Box
Joined Feb 23, '12
From Warrior, AL
QUOTE (mkernz22 @ Aug 14, 2013 - 5:48 PM) *
Source:
That's good to know, and makes life a lot easier. Hell, if you have the GT finding a smashed up 97 Camry shouldn't be too hard.
post Aug 26, 2013 - 4:15 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
and get one with no immobilizer
Lo-Fi Version Time is now: November 24th, 2024 - 11:48 AM
