> 1MZFE/S54 axle thread., Interesting info here, read up.
post Aug 15, 2013 - 5:02 PM
bnr32celica
Joined Jan 16, '12
From 860, ct
So, I'm in the midst of my swap here, and I'm at the point where my credit card is almost ready to melt haha. In any case, I came across some interesting information here for guys in the struggle like me.
As we all know, the Celica uses a carrier mount for the passenger drive axle. This carrier mount doesn't bolt up to 1MZ. We have only had one option at this point, and that's to make a custom carrier mount for our axles (or go E153).
What I found is this: a 2G MR2 uses the exact same spline count as us, and is a 1-piece axle with no carrier. I should mention this pertains to 5SF models only. However, there is a slight issue with using the MR2 axle. The MR2 axle is 1 1/4" shorter than our axles compressed to compressed. However, for any competent shop to lengthen the axle the required amount shouldn't be prohibitively expensive.
I brought this up because while most of us are competent enough to do the swap, not all of us can fabricate. I will get prices for a rough idea of the conversion of length tomorrow.
I also can't take all the credit for this idea...Smaay brought it up. I'm just going to see if it works. I hate the carrier mount assembly with a passion, and with space at a premium in the back of the bay, this could be a godsend.
post Aug 15, 2013 - 7:37 PM
kurt95gt
Joined Aug 23, '11
From kenton ohio
I will have to keep this in mind for my next v6
94 st hatch my daily driver
n
post Aug 15, 2013 - 7:43 PM
bnr32celica
Joined Jan 16, '12
From 860, ct
I'm just keeping with my goal of making this swap as painless as possible. Still won't be a day job like a Honda, but the more parts that can be sourced off the shelf, the less downtime and fabrication needed, therefore allowing more people to do the swap.
Lo-Fi Version Time is now: November 26th, 2024 - 12:15 PM
