> Headlight mod, Keep all four lights on without blinding
post Aug 15, 2013 - 9:35 PM
6gCeliMitch
Joined May 7, '11
From Olive Branch, MS
Any ideas guys? I wanna have all four headlights on all the time without blinding folks. is there a way to do a kinda drl setup for the highs so they run at half power until I hit a switch? Maybe set a relay to switch between a regular wire and one with a resistor?
post Aug 15, 2013 - 10:02 PM
Box
Joined Feb 23, '12
From Warrior, AL
Anything is possible, but why? Properly aimed low beams with the best halogens is more than sufficient.
2001 Miata LS 5-speed
post Aug 15, 2013 - 10:22 PM
JoshuaM
Joined Mar 6, '12
From Brisbane, Australia
There is a guide on CCUK - it is called the quad headlight mod or something and involves wiring a parker bulb into you highbeam housing.
Here is is;
http://www.celica-club.co.uk/wiki/index.ph...ight_Conversion
post Aug 15, 2013 - 10:29 PM
azian_advanced
Joined Apr 18, '05
From Calgary
two sets of DRL modules should do the trick.
post Aug 16, 2013 - 7:01 AM
6gCeliMitch
Joined May 7, '11
Just somethin different. I think I'll check out that guide thanks.
Lo-Fi Version Time is now: February 23rd, 2025 - 9:28 AM
