TOM'S 3S-GE N/A, 231 horsepower |
Aug 15, 2013 - 10:44 PM |
I just saw this on the TOM'S racing page and never heard of this engine ever existing.
QUOTE Complete Engine 2.2 Liter 3S-G - MSRP/ 1,365,000 Yen (1,300,000 Yen w/o tax) ~ (Price will vary due to customization) Product made upon purchase - Specs/ Displacement 2,253cc, Bore x Stroke 87.0x94.8, Max Power 172kW(235ps)@6,800rpm, Max Torque 255Nm(26.0kgf-m)@4,400rpm - Components/ 2.2 Liter Forged Pistons, 2.2 Liter Crankshaft, F3 Gasket, F3 Camshafts (IN&EX 256), TEC2 Computer, Lightened Flywheel - Vehicle Application/ MR2 (1989~1997 SW20 equipped with 3SGE), Other Vehicles Equipped with 3SGE (Excludes VVT-I engines) For Further Details (TEL:0550-89-8397) ~$14,000 USD Source: http://www.tomsracing.co.jp/products/parts...s.php?mprID=285 -------------------- -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- |
Aug 15, 2013 - 10:51 PM |
Enthusiast Joined May 31, '11 From Rochester, NY Currently Offline Reputation: 5 (100%) |
Seeing that price is probably why it isn't in anyones car lol.
-------------------- 1994 Toyota Celica GT-S 5S-FE 190k Miles. Project car 1992 Toyota Celica GT 5S-FE 170k Miles. Daily driver/beater 1999 Toyota Camry LE 5S-FE 216K Miles. RIP You will be missed. *ASE Certified General Manager |
Aug 16, 2013 - 1:20 AM |
Moderator Joined Nov 5, '07 From New Zealand Currently Offline Reputation: 3 (100%) |
sweet picture
<--- can get finer details if people want them? -------------------- |
Aug 16, 2013 - 2:28 AM |
Seeing that price is probably why it isn't in anyones car lol. Indeed. I can think of so many other things to buy that'd be better. -------------------- 2001 Miata LS 5-speed
Aug 16, 2013 - 8:17 AM |
Enthusiast Joined Feb 2, '07 From Berlin, WI Currently Offline Reputation: 18 (100%) |
at that price you can convert your car to a legit GT-four.
-------------------- *1997 Celica ST - 3SGE Greytop BEAMS *1977 Celica RA29 - Classic Cruiser *2005 Matrix AWD - dedded but still hanging around like a ghost 2019 Rav4 XLE Premium - Sports mode is fun. |
Aug 16, 2013 - 9:48 AM |
at that price you can convert your car to a legit GT-four. Or pay someone off to import one in really good condition lol. Unless by convert you mean converting those little metal plates lol. -------------------- 1994 Toyota Celica GT-S 5S-FE 190k Miles. Project car 1992 Toyota Celica GT 5S-FE 170k Miles. Daily driver/beater 1999 Toyota Camry LE 5S-FE 216K Miles. RIP You will be missed. *ASE Certified General Manager |
Aug 16, 2013 - 10:57 AM |
So a high compression 5S-GE N/A with cams and useless exhaust-cam VVT-i does 231 flywheel HP and that's impressive?
Ni**a plz... Get a 3SGTE head, slap it on your 5S, get 3rd gen 3SGE cams and 11:1 comp pistons and you'll probably have 231 wheel horsepower with a proper tune. -------------------- 1993 Celica GT Coupe - sold
1994 Celica GT Liftback |
Aug 16, 2013 - 6:30 PM |
Enthusiast Joined Mar 8, '12 From Hanford/Fresno, Ca Currently Offline Reputation: 20 (100%) |
So a high compression 5S-GE N/A with cams and useless exhaust-cam VVT-i does 231 flywheel HP and that's impressive? Ni**a plz... Get a 3SGTE head, slap it on your 5S, get 3rd gen 3SGE cams and 11:1 comp pistons and you'll probably have 231 wheel horsepower with a proper tune. That's exactly what came in mind once I saw the 2.2. Lol. The 5s block can provide a lot of power. It's just the fe head that makes it lack power. -------------------- |
Aug 16, 2013 - 6:42 PM |
Enthusiast Joined Jan 16, '12 From 860, ct Currently Offline Reputation: 0 (0%) |
Fappin' all day, fappin' all night.
I NEED this. Who needs their inheritance early? I'll do it! |
Aug 19, 2013 - 5:48 PM |
Enthusiast Joined Oct 25, '11 From Tbilisi Currently Offline Reputation: 3 (100%) |
at that price you can convert your car to a legit GT-four. I always wanted to ask that question. Usually how much $ is necessary to convert celi to a full GT-Four in USA? Thanks -------------------- |
Aug 19, 2013 - 8:01 PM |
Pistons & crank developed from the F3, JTCC.
2,253cc, Φ87mm 94.8mm. CR unknown the 5S-FE is 2,164cc Φ87.1mm 90.9mm In & Ex cams: 256deg, 10.5mm lift Factory: In: 252deg, 9.8mm lift Ex: 240deg, 8.2mm lift Not a whole lot bigger, though it isn't higher reving. Would have been nice to see the specs of '@ 1mm valve lift' instead of advertised duration. Also that price is from when it first came out in the 90's, so price has probably dropped. It doesn't have any VVT-I. Seems a bit pointless sourcing a gen 3 3SGTE head and then 3SGE cams. Just get the gen 3 3S-GE head with the cams in it already, as the heads are pretty much identical. -------------------- |
Aug 20, 2013 - 12:37 PM |
Pistons & crank developed from the F3, JTCC. 2,253cc, Φ87mm 94.8mm. CR unknown the 5S-FE is 2,164cc Φ87.1mm 90.9mm In & Ex cams: 256deg, 10.5mm lift Factory: In: 252deg, 9.8mm lift Ex: 240deg, 8.2mm lift Not a whole lot bigger, though it isn't higher reving. Would have been nice to see the specs of '@ 1mm valve lift' instead of advertised duration. Also that price is from when it first came out in the 90's, so price has probably dropped. It doesn't have any VVT-I. Seems a bit pointless sourcing a gen 3 3SGTE head and then 3SGE cams. Just get the gen 3 3S-GE head with the cams in it already, as the heads are pretty much identical. 2nd gen GTE head, 3rd gen cams (very common mod) is what I meant. It's a lot cheaper than sourcing a 3rd gen 3S-GE head in the US... -------------------- 1993 Celica GT Coupe - sold
Aug 22, 2013 - 11:06 AM |
at that price you can convert your car to a legit GT-four. I always wanted to ask that question. Usually how much $ is necessary to convert celi to a full GT-Four in USA? Thanks offtopic? -------------------- |
Aug 30, 2013 - 1:59 AM |
Enthusiast Joined Aug 26, '11 From ventura, ca Currently Offline Reputation: 10 (100%) |
how feasible is it to really build a performance hybrid version of the 5sfe? just curious as to what the reality of it being built is.
Aug 30, 2013 - 10:10 AM |
how feasible is it to really build a performance hybrid version of the 5sfe? just curious as to what the reality of it being built is. Very feasible. Nobody has done it because it's an all-custom build. 5S-FE block and crank, 3SGTE head, hybrid pistons, rods...etc. The power will really be at 11.5:1 compression, high lift cams (10mm lift minimum) with decent duration, etc... -------------------- 1993 Celica GT Coupe - sold
Aug 30, 2013 - 4:26 PM |
I know putting GE cams into a GTE head is pretty well known, but still seems odd to me to use the older gen 2 head, with the valve/shim set up (but if you're putting new cams in then you're most likely going to address this) and the ports which had tvis and poor flow from memory.
22#deg @ 1mm valve lift for the cams, maybe a staggered set up for more mid range. another thing is a reverse head set up... 300hp NA 2L 3S-GE 8,500rpm rev limit reversed head dry sump slide throttle body 6 Speed Sequential DBR box with electronic flat shift Carbon/carbon clutch -------------------- |
Sep 6, 2013 - 1:20 PM |
Enthusiast Joined Aug 4, '11 From Texarkana Texas Currently Offline Reputation: 0 (0%) |
Thats a sick set up!^^^
Sep 6, 2013 - 1:41 PM |
so basically it hasnt been done because a 3s swap is alot easier.
Sep 6, 2013 - 5:17 PM |
it is a 3S...
Sep 15, 2013 - 12:39 AM |
Enthusiast Joined May 12, '06 From Wilmington, NC Currently Offline Reputation: 45 (100%) |
I doubt you could get your hands on one of these engines if you tried. They were most likely built for race teams that wanted the best of the best. Sure you could build a hybrid engine for cheaper, but you're comparing a budget garage build to a fully built stroker engine made by a high-end brand name company.
This post has been edited by 6strngs: Sep 15, 2013 - 12:39 AM -------------------- 94 GT - Sold -------- 69 Pontiac Lemans - Sold 88 Alltrac - Sold ---- 04 WRX - Sold 00 GT-S - Sold ------ 91 Miata - project/drift car 95 GT - Sold -------- 96 GT - New Daily Drive |
Lo-Fi Version | Time is now: January 10th, 2025 - 5:50 AM |
