> Spacers, discussion/pictures on spacers brand, cost, vendor, ect...
post Aug 20, 2013 - 11:46 AM
Overkill
Joined Jul 27, '04
From Houston
Hey guys,
I searched the forums for a definitive thread on spacers and could not really find one. There is a lot of talk about spacers through out the forums in different threads, but thought we could all have one spot to share our experience.
What year car do you drive?
What size spacers are you using?
Where did you get the spacers?
Do you have a picture to show?
Show us your stuff!
post Aug 20, 2013 - 11:56 AM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
Ive had good experience with H&R 15mm (extended stud) and 25mm (bolt on) Spacers.
I recently bought and installed custom 21mm spacers from Motorsport-tech.
Everything has worked fine for me. As a tip I would spread a thin layer of anti-seize on the surface that mates to the hub and rotor. Spacers tend to fuse themselves to the hub
エキサイティングカーレーシングチーム!
post Aug 20, 2013 - 1:20 PM
ILoveMySilly97
Joined Mar 8, '12
From Hanford/Fresno, Ca
I've always used Ichiba spacers and they've never failed on me. Always come out in good shape and it's lasting good.
post Aug 20, 2013 - 10:31 PM
cyberblader1130
Joined Oct 24, '09
From Appleton, Wisconsin 54915
I've been using Ichiba 25mm spacers for awhile now on my 95 GT and i haven't had any issues. Bought them off ebay.
post Aug 21, 2013 - 3:55 AM
Chovies
Joined Mar 1, '12
From Sydney, Aus
Will these fit ? Details look right but the fitment section says 99-07 Celicas
http://justjap.com/store/product.php?produ...cat=&page=1
And would i be buying 1/2/4 for that price ?
Listen, Like and Share my bands page on facebook !!!
https://www.facebook.com/AwakenedAus
post Aug 21, 2013 - 4:03 AM
Timmyface
Joined Apr 17, '10
From Maitland, NSW
Are there no 94 ones on there?
They will work,
Edit: centre bore is the same!
15mm, make sure you have sufficient room on the back of your wheel to accommodate for the original studs poking through.
And that price is for a pair. $10 shipping I believe.
This post has been edited by Timmyface: Aug 21, 2013 - 4:04 AM
post Aug 21, 2013 - 4:16 AM
JoshuaM
Joined Mar 6, '12
From Brisbane, Australia
QUOTE (Chovies @ Aug 21, 2013 - 3:55 AM) *
You would be buying a pair for that price. Specs are right, only thing is 15mm bolt ons you need to have very deep cut out in the backs of your alloys where the stock bolts go through, or grind off your stock studs (or replace them). Need 25mm to clear the stock studs.
EDIT: Timmy's comment hadn't loaded when I started my reply tongue.gif
This post has been edited by JoshuaM: Aug 21, 2013 - 4:21 AM
post Aug 21, 2013 - 10:18 AM
ILoveMySilly97
Joined Mar 8, '12
^, +1.
post Aug 21, 2013 - 10:22 AM
ILoveMySilly97
Joined Mar 8, '12
QUOTE (cyberblader1130 @ Aug 20, 2013 - 8:31 PM) *
What kind of rotor is that?
post Aug 21, 2013 - 11:33 AM
cyberblader1130
Joined Oct 24, '09
I'm not really sure on the brand, it was an eBay knockoff but i haven't had any issues with them.
post Aug 21, 2013 - 1:30 PM
ILoveMySilly97
Joined Mar 8, '12
Was thinking about getting some eBay knock off ones. Since I don't even track my car. Do they still bite as good as the OEM ones though?
post Aug 21, 2013 - 3:44 PM
cyberblader1130
Joined Oct 24, '09
I can't say for certain since i have organic pads on there right now. Would be better to test them with ceramic pads. I rarely use them since i downshift every time i have to stop.
post Aug 21, 2013 - 7:20 PM
ILoveMySilly97
Joined Mar 8, '12
Too bad I barely bought my ceramic pads last year. I'll wait til mine wears out before purchasing a set. smile.gif
post Aug 22, 2013 - 2:55 AM
Chovies
Joined Mar 1, '12
From Sydney, Aus
QUOTE (Timmyface @ Aug 21, 2013 - 5:03 AM) *
They will work,
Couldn't see any 15mm that said 94 that's why i wasn't sure.
Don't really want to replace/ cut the studs though kindasad.gif
post Aug 22, 2013 - 7:20 AM
QUOTE (ILoveMySilly97 @ Aug 21, 2013 - 2:30 PM) *
Since you don't track it I would just suggest OEM, Brembo, or Raybestos blank rotor.
Chovies, those studs are 12x1.5 - isn't our spec 12x1.25?
This post has been edited by SwissFerdi: Aug 22, 2013 - 7:23 AM
post Aug 22, 2013 - 7:40 AM
The_enD
Joined Apr 12, '13
From Bulgaria
Celica is 12x1.5
FS thread : Custom Celica parts made to order + more
Click the image to visit my FB page
post Sep 2, 2013 - 4:46 PM
ILoveMySilly97
Joined Mar 8, '12
QUOTE (The_enD @ Aug 22, 2013 - 5:40 AM) *
Celica is 12x1.5
Add on to that. Our cars will fit any 5x100 bolt pattern, 12x1.5 thread size, and 54.1 centerbore with plug and play. In other words you can search up Scion TCs or any other 5 lug celicas and you'll be fine. I believe Subaru Imprezas also have the exact same size as us.
post Sep 2, 2013 - 6:01 PM
The_enD
Joined Apr 12, '13
From Bulgaria
QUOTE (ILoveMySilly97 @ Sep 3, 2013 - 12:46 AM) *
Celica is 12x1.5
I believe some Imprezas are 5x114.3.
post Sep 2, 2013 - 6:36 PM
ILoveMySilly97
Joined Mar 8, '12
The impreza only has the same bolt pattern. They got different thread size and centerbore.
http://www.boltpatternguide.net/Subaru/Sub...t_Patterns.html
This post has been edited by ILoveMySilly97: Sep 2, 2013 - 6:36 PM
post Sep 2, 2013 - 6:43 PM
The_enD
Joined Apr 12, '13
From Bulgaria
Just go on ebay and look for OEM WRC wheels. There are 114.3 and 100. What am I am saying is don't go in blindly into buying without checking the pattern.
Lo-Fi Version Time is now: January 10th, 2025 - 9:57 AM
