> A Crack in the Air Intake Hose Can Do THIS???
post Aug 20, 2013 - 4:39 PM
FrankB2
Joined Oct 25, '12
From Pennsylvania
Bought my '97 Vert last October, and the rpm's were erratic with the AC on, and a growl roared from under the hood when passing cars....or just punching it. I changed the air filter, but didn't notice any cracks in the hose. I had the oil changed last week, and they must have given the hose a good tug. I opened the hood just to give things a routine look while the engine was running this morning, and heard a sucking sound. The air intake hose had a tear 3/4 of the way around, with about an 1/8" gap. I ran some duct tape around it (had to remove the hose and resonator under it), and ordered a new hose. Now it idles like a Swiss clock, and there's no more growling at WOT. This was a crack that I hadn't noticed before, and I did look at that area before, so it must not take much to degrade performance! Zero to sixty was much smoother this afternoon, and absolutely quiet. The new hose is supposed to be here in 3 days, and was $13 from the local Toyota dealer.
Just thought this might help someone......
post Aug 20, 2013 - 9:55 PM
Galcobar
Joined Mar 3, '05
From Richmond, B.C.
Vacuum leaks, unfiltered air, and probably most importantly getting most of your air from the hot engine bay rather than the intake, thus bypassing the intake air temperature sensor and fooling the ECU into thinking it's working with cool air.
post Aug 20, 2013 - 10:41 PM
FrankB2
Joined Oct 25, '12
From Pennsylvania
My first thought after removing the air sensor was that might be the biggest problem of all. Those engine bays are pretty hot, and that sensor probably wasn't doing anything useful. The idle is higher now, and much more steady. The rest of the car is holding up perfectly, but the valve cover gasket could use replacing. It's been seeping a tiny bit since I bought the car, but the oil level never goes down. I get compliments constantly, mostly from middle age guys....LOL
Lo-Fi Version Time is now: November 26th, 2024 - 1:30 PM
