Antenna Down? |
Antenna Down? |
Aug 22, 2013 - 9:45 AM |
Enthusiast Joined Jul 23, '13 From Marlborough, MA Currently Offline Reputation: 0 (0%) |
Im not trying to remove the whole antenna but i want to get it to go all the way down. mine just stops going down right at the end. someone help please.
Aug 23, 2013 - 2:10 AM |
Best I can figure is that some of the teeth on the plastic track broke off or wore down, so the gear which raises and lowers the antenna mast is slipping on a specific section. Alternately, the track may have gotten twisted inside the motor and is not allowing the mast to drop all the way. The third option, which I consider most likely, is that the top portion of your antenna mast was bent and therefore doesn't fit inside the portion below it.
Sep 21, 2013 - 6:05 AM |
Enthusiast Joined Sep 23, '12 From Australia Currently Offline Reputation: 4 (100%) |
Mine used to do this sometimes too, other times it would go completely down... I got sick of it's looks, opened the internal boot panel, disconnected its power source, then disconnected the antenna and re-routed it to the roof. Bought a $12 Shark-fin antenna, drilled a hole in my roof, fastened and sealed the antenna with Silicone and that is now my antenna
I used to just physically push my antenna down the last bit when it didn't work, but unless you are prepared to break it, don't do this -------------------- ------------------------------| White '94 Celica | Bought 11/05/12 | Sold 12/05/15 |------------------------------ |
Sep 26, 2013 - 12:33 AM |
if you still want to use radio, then you are stuck until you get a new motor. or switch to s2000 antenna.
Lo-Fi Version | Time is now: November 29th, 2024 - 10:05 PM |
