Enthusiast ![]() Joined Oct 30, '12 From Cheshire Currently Offline Reputation: 0 (0%) ![]() |
Hi
Installing aftermarket central locking, got the 12v constant working fine, grounded well, cannot suss out the lock/unlock connections at all. The locking unit im installing has two white (lock) wires and one white/black (unlock). After taking advice on here previously i connected the lock wires to the blue/black wire that plugs into the locking module (next to the steering column) but the unlock is supposed to be connected to a blue/green in the same location. I cant find a blue/green so after some googling i went into the solid blue, nothing, tried plenty of alternatives too and nothing. The unit itself is powering up and clicks when i press lock or unlock on the fob, the LED flashes when set to lock too Please can someone help, with some connection advice, this is killing my brain now ![]() |
![]() Enthusiast ![]() ![]() Joined Jul 17, '12 From Slovenia Currently Offline Reputation: 0 (0%) ![]() |
As far as I remember, lock/unlock wires are located behind the kick panel under the steering wheel. (cheat sheet)
Thanks Nihal
I already had that cheat sheet and just realised im a total idiot, i was looking for a blue/green singular wire not realising that it means a blue wire and a green wire (so technically three connections in total for the locking aspect) - doh! |
Lo-Fi Version | Time is now: February 22nd, 2025 - 12:38 AM |
