> Going from C52 to C160 LSD, What's all involved?
post Aug 23, 2013 - 6:24 AM
onnaj
Joined Sep 6, '12
From Holland
Hello,
Next week i'm recieving my C160 gearbox with LSD from the AE111 Levin. It comes with the shifter cables and lever. I have some questions though, hopefully someone can answer them.
1) Can i use my C52 shift cables and lever or do i absolutely need to change them?
2) Can i use my C52 axles?
3) Do i need special LSD oil, normal gearbox oil or whatsoever?
4) what should i need more? For example use a 'TRANSAXLE OR TRANSMISSION ASSY & GASKET KIT (MTM)'?
5) Do i need to adapt the shifter box to be able to reach the reverse gear?
Thanks!
post Aug 23, 2013 - 5:26 PM
bnr32celica
Joined Jan 16, '12
From 860, ct
Inner CV joints are different. You may end up needing to purchase a set of 00-05 GTS axles for an LSD car strictly for the inners.
I don't see you needing to swap cables and shifter box. Kseries guys that go from the A3 box to a A2/Z1 box just do the trans swap. Just make sure there's not a reverse lockout wherein one would have to push down or something like in VWs. That might be your only downfall.
You only need a gasket kit IF you crack open the case.
I would definitely run gear oil optimized for LSD, along with a friction modifier (commercially available).
I assume it mounts the same to the crossmember and frame, so maybe new trans mount and motor mounts as a precaution. You're in there.
You might need to buy a new clutch disk if the spline counts are different. I can't confirm or deny that however, but I have a friend who can.
Best of luck, this should make the ST move a little faster with the better ratios.
post Aug 23, 2013 - 6:37 PM
BonzaiCelica
Joined Apr 24, '08
From Orange County, CA
us s54 helical oem lsd guys don't run nothing special for the lsd. just 75W-90
post Aug 24, 2013 - 1:19 AM
onnaj
Joined Sep 6, '12
From Holland
QUOTE (bnr32celica @ Aug 24, 2013 - 12:26 AM) *
I'm nist going to use the C60 gearbox, but the OEM 4age 20v blacktop C160 gearbox. I know the C60 had different axles and bellhousing, but does this also count for the C160?
Lo-Fi Version Time is now: January 7th, 2025 - 10:55 AM
