> 3sgte 3rd gen, PLEASE help me finish my swap!!
post Aug 24, 2013 - 6:29 PM
celicaGT96
Joined Aug 14, '05
From Corpus Christi Tx
Okay here it goes... I've been laying low for a long time researching, learning and trying to get my swap compete. I am no mechanic and I have zero help. I tried very hard to search and figure everything out for myself but I can't find what I'm looking for. It's been years unfortunately and I need to finish up. Can someone please help me out with these last few things so I can get my baby on the streets once again? I have a 3rd generation 3sgte with a fmic installed and aftermarket bov. My question is exactly where is the best place to tap into for my bov (near the throttlebody) and also for the external wastegate? Pictures would really help. I'm having trouble posting pics from my phone. Thank you
post Aug 25, 2013 - 3:23 AM
celicaGT96
Joined Aug 14, '05
Anybody?
post Aug 25, 2013 - 6:21 AM
Jeebus
Joined Apr 21, '13
From YYC
Would pics from my stock '94 GT-Four help? I can grab you some pics over the next few days when I get off work.
post Aug 25, 2013 - 11:00 AM
celicaGT96
Joined Aug 14, '05
I'm having trouble rerouting for an after market bov and wastegate (like where to tap into for pressure lines or vacuum ) but any detailed pics should help. Thank you
post Aug 25, 2013 - 4:36 PM
delusionz
Joined Feb 11, '08
From Auckland, New Zealand
wastegate comes from a pressure source as close to turbo as possible
bov comes from manifold vacuum, find a spare port on your manifold if not available tee it
I'm really not sure you should be working on this yourself if you're confused by such simple common sense concepts though
Mike W
269awhp / 273ft-lbs
post Aug 25, 2013 - 5:49 PM
celicaGT96
Joined Aug 14, '05
That's how you learn. Simple as that. I did as you mentioned just wanted confirmation. Seems like I have that part done. Thanks for chiming in.
Can someone please let me know where the second hose goes to? I know the first goes to side manifold but what about the second one?
Also what goes here? Thank you
post Aug 25, 2013 - 8:48 PM
delusionz
Joined Feb 11, '08
1. aircon idle up, it's a bypass to allow extra air to get past the closed throttle , this is active while you drive when AC is on.
So logically, where do you think it goes? Hint: We wouldn't want to leak boost while on throttle.
2. main idle source port. okay ill tell you now it goes to the air filter or any atmo
if it were on its own, it could go back to a pressure source, but as it has other atmo breathing lines attached to it (ie, wastegate relief & power steering idle up on full lock) it must go back to atmo.
You need to understand why though, theres no sense in you plugging things in because some guy on the internet told you to do so
Mike W
269awhp / 273ft-lbs
post Aug 25, 2013 - 9:27 PM
celicaGT96
Joined Aug 14, '05
Trust me I couldn't agree more I WANT to understand what's going on with my car. So are you saying that both the idle up and the other port can be routed to the intake? That's the only thing I can think of..?
post Aug 29, 2013 - 12:13 PM
Jeebus
Joined Apr 21, '13
From YYC
It's been a little rainy here (typical), and since my car is on stands in the garage so the lighting isn't great. Just wanted to know whether you still needed some pics? I'll get to them as soon as the sun comes out if you do need em.
post Aug 29, 2013 - 7:10 PM
celicaGT96
Joined Aug 14, '05
I would yes. I still haven't confirmed my questions. I just want to get this done. Thank you
post Aug 31, 2013 - 2:53 PM
Jeebus
Joined Apr 21, '13
From YYC
Finally a sunny day after a week of rain!
Hope these pic help! I tried to colour code them for you.
Hope these help!
This post has been edited by Jeebus: Aug 31, 2013 - 2:58 PM
post Sep 1, 2013 - 3:05 PM
celicaGT96
Joined Aug 14, '05
This IS EXACTLY what I was looking for!! Thank you so much for taking the time to help me out and even color coding them. Very easy to understand and it tells me just what I needed to know. Thanks again!
post Sep 1, 2013 - 3:12 PM
Jeebus
Joined Apr 21, '13
From YYC
QUOTE (celicaGT96 @ Sep 1, 2013 - 4:05 PM) *
Glad to have helped
Just don't judge me on the MacGyver- job on my air filter. The previous owner didn't have the proper coupling, and there was about a half-inch gap between the fitting from the filter to the intake hose. I'm probably going to replace it with an Apexi power intake soon.
This post has been edited by Jeebus: Sep 1, 2013 - 3:13 PM
post Sep 2, 2013 - 5:25 PM
Pfloyd09
Joined Jul 15, '13
From USA
Very nice man. Good to see ppl take the time to do nice things. The color coding made me laugh a bit too. smile.gif
post Sep 10, 2019 - 12:30 PM
Ross_e92
Joined Sep 10, '19
From Rasta1992
QUOTE (Jeebus @ Aug 31, 2013 - 2:53 PM) *
Hope these help!
Evening, I know it's been a few years since this post but I could really do with viewing those photos, yet it won't allow me too, is there anyway which these could be forwarded?
Any help would be great, not expecting a reply but hope is a great thing.
Thanks
post Oct 17, 2019 - 7:47 PM
xRaveNx
Joined May 21, '05
From New Jersey
same, I'm building a 4th gen and could use some help with piping and wiring... please help lol
post Nov 6, 2019 - 2:00 PM
J3rkyBoy
Joined Mar 27, '18
From Seattle WA
Ditto. Please.
Lo-Fi Version Time is now: April 22nd, 2025 - 7:20 PM
