> 3SGE ECU from ST202 the same on JDM and EU spec ?
post Aug 30, 2013 - 11:09 AM
Iceman22
Joined Dec 16, '08
From Norway
Hello.
My question is if someone know if there are any differences on the following ecu's:
6gen celica rev3 engine,
- 3SGE JDM spec 94-99
- 3SGE EU spec, 94-95 before EGR was installed
- 3SGE EU spec, 96+ with EGR
Are all ecu using the same part numbers?
And can I use for instance a eu spec ecu on a jdm engine?
I tried toyodiy.com, but I can't find any ecu there.
- Celica ST202 w/ JDM 3S-GE 180HP (Special LE Subaru Blue steel paint!)
- A video of my car, before & after: Click here
post Aug 30, 2013 - 5:17 PM
Rusty
Joined Nov 5, '07
From New Zealand
you'll find the ecu in:
Electrical > Electronic fuel injection system
Computer, engine control.
afaik they have all the same plugs and pin out. but the +EGR probably has an additional wire
JDM ecu will have speed cut at 180km/h, not 100% sure the EU have it
post Aug 30, 2013 - 6:05 PM
Iceman22
Joined Dec 16, '08
From Norway
Thanks! Finally I found what I was looking for.
EU does not have 180km/h cut.
The JDM ecu have different part number than the euro spec (non egr), but as far as I know the JDM 3sge has slighly higher compression ratio, so it produces 178HP,
while the EU spec (non egr) produce 175 or 173.
Wonder if the JDM engine would run well on a eu spec ecu...
This post has been edited by Iceman22: Aug 30, 2013 - 6:43 PM
Lo-Fi Version Time is now: December 12th, 2024 - 10:44 AM
