> its my fault. NO BRAKES
post Sep 5, 2013 - 6:37 PM
CrossCudi
Joined Mar 10, '11
From New Jersey
So my spacers came in with my extended studs for my rear,
I raised my car, removed the wheel, found my 2 screws to insert in
the available location to removed the rotor. as I kept screwing away
the rotor was moving out but it was coming off. than I noticed I had my Ebrakes up !!!!
I knew from the amount of screwing I did I had to damage something inside.
I released my ebreaks and the pressure was releases and rotor came off along with these:
I was so mad at myself, so I continued with the process,
the other side was done successfully and noticed that
those parts came from here:
I knew that was a crucial damage...
got in my car after I was done and break pad when pressed just sunk straight down with no pressure..
stepped on it a few times and still the same..
now I have no brakes and looks like I will need a new driver side rear drum setup.. ?
94' Celica GT Manual
post Sep 5, 2013 - 7:02 PM
soulshadow
Joined Apr 18, '05
From Lincoln, Ar
Your brake hardware fell out. You can easily get them at your favorite auto parts store for less than $15. By the reading of your post, it may sound like you need a new drum brake wheel cylinder that activates the drum brakes on the side that fell out. You may also want to check the shoes and the drum itself.
post Sep 5, 2013 - 7:31 PM
CrossCudi
Joined Mar 10, '11
From New Jersey
thanks, I just called, u were right they had everything u mention.
post Sep 5, 2013 - 8:14 PM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
easy but annoying fix!
エキサイティングカーレーシングチーム!
post Sep 5, 2013 - 8:36 PM
CrossCudi
Joined Mar 10, '11
From New Jersey
if u have any experience with this, would love for u to share b4 I break something else,.. thanks
cheela
Joined Feb 2, '07
From Berlin, WI
do the easier fix and switch to discs in the back. hahahah that's what I'm waiting to do. I hate changing the drum brakes.
post Sep 5, 2013 - 8:41 PM
CrossCudi
Joined Mar 10, '11
From New Jersey
I have 2 complete swaps offers at 200$
im really not trying to spend that money,
I need a new radiator, but if I continue
to think about it I just might buy a set, ..
post Sep 5, 2013 - 8:48 PM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
EWWWWWWWWW DRUUUUUUMMMMMSSSS
エキサイティングカーレーシングチーム!
post Sep 7, 2013 - 3:02 PM
CrossCudi
Joined Mar 10, '11
From New Jersey
Ok so I bought all my parts and the guy at the shop was trying to explain to me the bleeding process but I didn't understand him at all.. Can someone help me here.
Thanks
post Sep 7, 2013 - 10:43 PM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
its laaaattee. if nobody responds by tomorrow morn ill type up a how to for ya
エキサイティングカーレーシングチーム!
post Sep 8, 2013 - 8:15 AM
QUOTE (Tigawoods @ Sep 7, 2013 - 11:43 PM) *
its laaaattee.
I prefer cappuccino.
post Sep 8, 2013 - 9:16 AM
Bitter
Joined Mar 11, '06
From Way South Chicago
http://www.youtube.com/watch?v=MfTmlOZbXgs
Follow that to bleed the brakes, however its pretty likely you may have damaged the wheel cylinder on that side and the brake line may not be in the best shape, can of worms situation here. Check the wheel cylinders by popping the rubber boots on them back and looking for fluid. If you see fluid, you need new wheel cylinders.
post Sep 8, 2013 - 10:56 PM
soulshadow
Joined Apr 18, '05
From Lincoln, Ar
Drum brakes are prob the most difficult as *uck brakes to work on. It still takes me several tries to get all the springs back on right adjust the brakes right and then the E-brake and then drive around take the drum back out and check to make sure the shoes aren't holding the drums down or the wheel cylinders are leaking. PITA.
post Sep 10, 2013 - 8:25 AM
CrossCudi
Joined Mar 10, '11
From New Jersey
wow this job really sucked,.. !
never knew how many springs u had to replace
and pulling and having the right and PERFECT settings for this to work..
after taking about 3 hrs just on one,
going from the left one to the right one to match up correctly
the other took 15mins.
bleeding was alot easier having my friend help me.
Lesson Learn: dont forget to release Ebrakes while removing Drums !
Thanks alot guys !
post Sep 11, 2013 - 2:38 AM
Galcobar
Joined Mar 3, '05
From Richmond, B.C.
QUOTE (CrossCudi @ Sep 10, 2013 - 6:25 AM) *
Thanks alot guys !
That's a lesson to be learnt (gotta love archaic spellings) for disc setups too, since Toyota uses a drum-in-disc design with a drum emergency brake.
Lo-Fi Version Time is now: January 9th, 2025 - 7:25 AM
