> Awkward engine issue st204
post Sep 7, 2013 - 11:01 AM
st204downunder
Joined Sep 7, '13
From Sydney, NSW, Australia
Hey guys, was driving my 94 st204 back home from work at 90km/h normally on 5th gear, no traffic on a flat road when suddenly engine lost power, RPMs dropped to 300 and engine was barely running. Forced to the max to drive in low gears to the nearest service station (5 minutes from where the issue started), car had no power at all driving like @ 10km/h max in 1st gear going up hill, then on the flat and downhill could manage to engage 2nd and 3rd with rpms on 1800 tops and no power at all.
Engine was really hot as it was forced and a bit (not much) of coolant came from the little drain thing close to the cap where you fill the coolant in, waited good 40 minutes, topped the oil and water, checked spark plugs, cables and distributor cap (i had my tool box with most of my tools so i could remove the plugs on the spot) they were all clean with no weird signs of oil or corrosion... turn the engine on and the same issue, no power at all, RPMs low as 300/400 and i tried to move from the station. Drove like 800 metres when the engine died running down the hill (to not force the engine or anything I was going down the road on neutral). To avoid the steering wheel to lock and brakes to loose pressure I tried to start putting on 3rd and releasing the clutch, my surprise was the engine didn't start at all.
Reached the bottom of that road, on the flat and the car never started again.
When you try to start it sounds and look like will start normal but doesn't... Jump starting doesnt work either...
Left the car there for a couple of days (its far from home and I dont have much time to go there often, thank God it's in a safe spot in a nice suburb lol) today I went there and tried to start, engine started but only for a few seconds and really weak with RPMs low as 300 again frown.gif then didnt start anymore frown.giffrown.gif
My guesses are: MAF sensor (where the heck is it in the st204?), fuel pump, timing belt (could it be the timing belt if the engine started again?!), some stupid wire that I couldn't find, some vacuum issue, any other problems with the whole air intake system? I have no idea and don't have the $ to start digging for the issue, I need to find a good guess that rules out most of the other options and pray i can fix it myself frown.gif
Any ideas? smile.gif Thanks everyone!
post Sep 7, 2013 - 11:56 AM
enderswift
Joined Jul 12, '08
Have you checked compression? also Take the cover off the timing belt and see if it jumped a tooth. Are you getting fuel? Maybe your pump gave out. A good way to check is to use starting fluid in the intake
post Sep 7, 2013 - 12:45 PM
richee3
Joined Jun 29, '08
From Denver
The 5S doesn't have a MAF. the timing belt could have skipped a tooth, fuel pump could have died, etc. Your best course of action would be to pull the codes from the ECU to see where to start.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Sep 7, 2013 - 12:52 PM
ILoveMySilly97
Joined Mar 8, '12
From Hanford/Fresno, Ca
Don't drive it or start it until its fixed or you can cause some serious damage. Should check the compression and go from there.
post Sep 8, 2013 - 10:47 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
based on your description, it sounds like your fuel pump died.
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Sep 8, 2013 - 10:53 AM
bsamps4
Joined May 16, '10
From Raleigh
if its the fuel pump, i just replaced my gas tank. the tank that i replaced it with had the old fuel pump set aside. it still works. if the scrap guy doesn't take it i might be able to get it to you.
post Sep 8, 2013 - 11:08 AM
JoshuaM
Joined Mar 6, '12
From Brisbane, Australia
Rentaspace is currently scrapping a 5th gen coupe with a 5S-FE in the Sydney area - that may use the same pump?
post Sep 8, 2013 - 1:16 PM
aspen
Joined Nov 29, '07
From Colorado
Every NA 6th Gen uses the same pump.
2019 M2, 2005 S2000, 1997 4Runne
post Sep 8, 2013 - 1:29 PM
richee3
Joined Jun 29, '08
From Denver
The 5th gen uses a 150 lph pump whereas 6th gens use 190 lph pumps.
1998 Celica GT-
BEAMS Swapped.
Lo-Fi Version Time is now: April 21st, 2025 - 4:45 AM
