> celica in trouble, engine is F*CKED i think.
post Sep 11, 2013 - 11:28 AM
insanescotsman
Joined Aug 15, '13
From falkirk,scotland
Hi everyone i have a 97 GT i love it and bought it as a project car. anyway the car revs free when its in neutral and dies on occasion. engine is a bit jumpy when you put your foot down or take it off. just wondring if anyone else has this problem.
Thanks guys and girls
post Sep 11, 2013 - 5:14 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
um yeah im going to need waaay more information
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Sep 11, 2013 - 10:36 PM
Roadrash
Joined Aug 31, '13
From Wyoming
lol, yeah if you want a real answer your gonna have to ask a real question. Give some specifics. What does "rev free" mean? does it mean it runs great while just idling in neutral? Jumpy? All the time while accelerating or just if you mash the gas pedal to the floor?
post Sep 12, 2013 - 7:36 AM
Bitter
Joined Mar 11, '06
From Way South Chicago
Definitely needs a new engine, I think maybe you might even need a replacement passenger side door too.
post Sep 12, 2013 - 4:32 PM
insanescotsman
Joined Aug 15, '13
QUOTE (Smaay @ Sep 11, 2013 - 6:14 PM) *
dunno what else to say man when i slow down to come to a set of lights it sometimes turns off and doesent start for a few minutes or it will do it after dropping to like 300RPM. and sometimes it revs itself even when the engines reached normal temperature. it also runs badly, like at constant speed it feels like its juddering a bit.
thats the only way i can explain it
post Sep 12, 2013 - 4:55 PM
Box
Joined Feb 23, '12
From Warrior, AL
Could just be a matter of needing a tuneup. Check compression across the cylinders, if that checks out the engine is fine and it's something menial.
2001 Miata LS 5-speed
post Sep 13, 2013 - 11:47 AM
cjh4l22
Joined Oct 18, '06
From cincinnati
QUOTE (Box @ Sep 12, 2013 - 5:55 PM) *
^definitely a good place to start, as bad compression ends this discussion. After that if you've got a little money start with the basics of a tune up. Good oil change, spark plugs, wires, maybe a distributor (be sure to check timing). If after the tune up you still have problems, I'd say check for a sensor that is going bad and causing it to go haywire. My guess... o2 sensor, mass air flow or maybe throttle position sensor just to name a few that come to mind.
Good Luck
post Sep 13, 2013 - 8:08 PM
insanescotsman
Joined Aug 15, '13
QUOTE (cjh4l22 @ Sep 13, 2013 - 12:47 PM) *
Good Luck
thanks man i think ill need it :]. hopefully its not too bad
post Sep 14, 2013 - 2:07 AM
Rusty
Joined Nov 5, '07
From New Zealand
remove intake pipe, see if the butterfly is fully closed, could be the throttle cable is under too much tension, or could be the TPS.
any CEL codes? put in diagnostic mode.
Lo-Fi Version Time is now: January 10th, 2025 - 12:46 AM
