Gearbox change - How to?, Going to install the new gearbox |
Sep 11, 2013 - 11:56 AM |
Enthusiast Joined Sep 6, '12 From Holland Currently Offline Reputation: 1 (100%) |
Hello,
I'm going to change my gearbox within the next month. I hope someone has a good how-to on changing the gearbox. I'm also changing to the shifter cable and the 6 gear box/w lever of the C160. So hope anyone can tell me how to tackle that part. And how should i remove my OEM Toyota (Victor) leather gearknob. First i unscrewed the bolt then I tried turning it, but it won't move. Any ideas. Thanks in advance. -------------------- |
Sep 11, 2013 - 5:13 PM |
i wrote this for 7th gens, but its going to be fairly similar
http://www.newcelica.org/forums/showthread.php?t=334603 -------------------- 2001 Celica GT-S Turbo
Sep 12, 2013 - 3:02 PM |
i wrote this for 7th gens, but its going to be fairly similar http://www.newcelica.org/forums/showthread.php?t=334603 Thanks! now i have to search how to replace the cables on the shifter box/lever itselfs and how to remove the gearknob. -------------------- |
Sep 12, 2013 - 7:17 PM |
Each cable is secured with a c-clip to a bracket on top of the gearbox. The ends are connected to the linkage via a rod and pin.
'93 MX-5 LE |
Sep 12, 2013 - 8:05 PM |
When you get to the shift linkage its pretty much self explanatory. You should be able to get it off from the car fairly easy.
Sep 13, 2013 - 2:06 AM |
When you get to the shift linkage its pretty much self explanatory. You should be able to get it off from the car fairly easy. And how should i remove the gear knob? -------------------- |
Sep 13, 2013 - 6:31 AM |
Twist harder? Every gearknob I've seen comes off one way, turning to the left.
You can see one c-clip in this picture. The bracket on the transmission is the same. This post has been edited by SwissFerdi: Sep 13, 2013 - 6:47 AM -------------------- '97 ST \ Eibach \ KYB \ Kenwood \ Alpine \ Cusco \ OEM+ [sold 10/18]
'93 MX-5 LE |
Sep 14, 2013 - 6:36 AM |
Twist harder? Every gearknob I've seen comes off one way, turning to the left. You can see one c-clip in this picture. The bracket on the transmission is the same. Thank, will try it! -------------------- |
Lo-Fi Version | Time is now: January 9th, 2025 - 7:31 AM |
