Removing the air intake hose + A'Pexi Power Intake |
Sep 12, 2013 - 2:39 AM |
Enthusiast Joined Apr 21, '13 From YYC Currently Offline Reputation: 1 (100%) |
Hey gang,
So my Samco Air induction hose had finally arrived in NYC, and was shipped out from NYC earlier this week to me. Now, it's time for me to start doing some homework. Just a recap, I'm quite sure the stock air intake hose was fine when I bought the car, but I noticed that the previous owner didn't have the mushroom air filter properly fitted to the air intake. I took matters into my own hand, as I was 11hrs away from the seller, and bought some plumbing supplies to properly attach the filter to the air intake hose so that there would be no gap between the two. I believe this process cracked the hose, at the point right before the hose connects to the turbo, as seen below: Now, with my mechanical skills (lack thereof), can someone please direct me in the proper direction to replace this myself? My front end is currently on jack stands, as I was fixing up my headlights, and still need to install a DRL relay (waiting for it in the mail). From what I can see, I'll have to remove the radiator hose immediate above the air intake hose so that I can unlatch it from the turbo. Will this require me to drain my radiator completely just for the hose? Also, I've never really handled the clamps used on the hose that are of the pinching variety (immediate left of the yellow circle I drew). Which tool do I need to remove the clamps? Thanks for the help in advance, I'm sure there'll be more questions to come when I actually get to doing this project. This post has been edited by Jeebus: Sep 21, 2013 - 4:42 PM |
Sep 12, 2013 - 10:27 AM |
Enthusiast Joined Jan 26, '09 From Los Angeles Currently Offline Reputation: 1 (100%) |
You DO NOT need to remove the radiator hose.
That double wired clamp that holds the tube to the turbo is just like the clamp that holds the mushroom to the other end of the tube.. There is a bolt somewhere along it that you loosen. Feel around for it and try to twist the ring so the bolt is accessible with a socket/screwdriver. So yeah, loosen those two odd looking clamps and pull the oil hose out of the tube and it should be free, iirc. -------------------- |
Sep 17, 2013 - 3:43 PM |
Thanks Malek, it really was simple. Two clamps on the larger ends were loosened with a flat head screwdriver, and I used some fat pliers to compress the clamp on the smallest hose. Was done in 10~15 minutes.
Sep 21, 2013 - 4:40 PM |
Got my A'Pexi Power Intake today, installed it with a few hiccups along the way, but finished fine.
But, the previous owner had used silicone to attach the intake air temp sensor to the HKS intake. Does anybody happen to know the part # for the grommet/bushing (or a parts # catalog for the ST205) so that I can properly attach the sensor into my new intake? I've looked through the Engine and Supplemental Repair Manual, plus the FAQs to no avail. Cheers! This post has been edited by Jeebus: Sep 21, 2013 - 4:41 PM |
Lo-Fi Version | Time is now: November 24th, 2024 - 9:32 PM |
