Block heater plug location?, Preparing for winter |
Sep 14, 2013 - 8:42 AM |
Enthusiast Joined Sep 6, '13 From Finland Currently Offline Reputation: 0 (0%) |
Could anyone tell where is the plug for block heater? 3S-GE engine. Winter is cold in here Finland so I need to install block heater.
Picture would be great This post has been edited by Disasteri: Sep 14, 2013 - 8:43 AM |
Sep 17, 2013 - 12:05 PM |
Enthusiast Joined Mar 24, '11 From 704 Currently Offline Reputation: 3 (100%) |
You need to find the block drain plug and screw one in there. I have no idea where its at on the 3s though so someone else will have to chime in on that.
If you can't find that, they make inline coolant heater/pump setups that T-Off into your coolant lines to heat up and circulate coolant. You hook it up when needed, and remove it when not needed. |
Sep 20, 2013 - 9:11 PM |
Enthusiast Joined Dec 9, '08 From Blainville Currently Offline Reputation: 4 (100%) |
Is there a block heater for the 3sgte??
Sep 23, 2013 - 7:32 AM |
You'll need to measure or know the diameter of an engine freeze plug, knock one out, and install the block heater into there. They're a universal fit product, so once you know the diameter you need they're easy to find for purchase however installation is somewhat difficult if you're not comfortable punching out freeze plugs. You can find how-to videos on YouTube easily to gauge your interest.
Lo-Fi Version | Time is now: December 4th, 2024 - 7:06 PM |
