2 Pages V  < 1 2
> 2nd gen 3sgte sorrows, coolant mixed with oil.
post Sep 26, 2013 - 4:54 PM
i cant see how you could screw up the water/oil lines on a ct based turbo.
water lines on top, oil lines on bottom, the lines/fittings arnt interchangeable.
the only other place i can think of is the oil cooler, but even then i cant see how one would get into the other.
better chance of the headgasket leaking, or somthing similar.
post Sep 26, 2013 - 5:36 PM
garin
Joined Aug 12, '07
From Lancaster, Pa
QUOTE (presure2 @ Sep 26, 2013 - 5:54 PM) *
yes! thank you manny for your input... also to jeff and art. just trying to think logically why this thing isn't doing what i ant it too. gonna compression test to and re torque the head. arp says 65 ft lbs in the oem sequence.
2 Pages V  < 1 2
Lo-Fi Version Time is now: November 28th, 2024 - 3:15 PM
