> The first Audi look LED-tails
post Sep 17, 2013 - 3:35 PM
BlackWidow
Joined Mar 12, '10
From netherlands
Because everyone has the kouki tail lights, i'd like to try something new.
Drilling 80 holes with 80 leds, and 10 hours work on 1 taillight, is this the result.
This week i try to build the unit on the car, and then we will see how it look like.
post Sep 17, 2013 - 3:58 PM
toyota123
Joined Jan 13, '12
From Georgia
Looks good what's the final plan... Anything between the original lights? Or are you planning for those to be the running lights?
97 Celica GT liftback DD/ project
96 corolla back up DD
post Sep 17, 2013 - 8:22 PM
Special_Edy
Joined Oct 29, '11
From Haltom City, Texas
Very nice! Does the bumpy texture of the lens distort the lines at all and do all 80 LEDs have seperate resistors?
post Sep 17, 2013 - 8:55 PM
bloodMoney
Joined Aug 4, '06
From Chicagoland
Looks cool! I've thought about doing this, but around each of the tail lamp features.....
Have you figured out how you're going to handle moisture/water intrusion issues?
~bloodMoney
post Sep 17, 2013 - 9:47 PM
Looks pretty good.
post Sep 18, 2013 - 10:04 AM
BlackWidow
Joined Mar 12, '10
From netherlands
@ toyota123: Here in the Netherlands we dont have to put on the lights 24/7. So i put them on when its dark. They replace the normal backlights. But i keep the original brakinglight.
@Special Edy: I drilled the holes in the backside of the tab, and thats just next to the bumpy texture, see the next pictures below.Yupp every led got a own resistor. 80 leds---> 80 resistors. I create groups of 20.
@ Bloodmoney: I am very creative with silicone biggrin.gif
post Sep 18, 2013 - 10:16 AM
yellowchinaman
Joined Aug 11, '08
From London
Nice. Im glad there is someone else who is being creative with the rear lights.
post Sep 18, 2013 - 10:23 AM
BlackWidow
Joined Mar 12, '10
From netherlands
Here you see the silicone, the leds and the resistors. And WHERE I drilled the holes.
At the front side, the light comes out of the thin dark line
post Sep 18, 2013 - 11:54 AM
The_enD
Joined Apr 12, '13
From Bulgaria
Should have used SMD LEDs, so much easier to mount, a lot less soldering, low profile, cheap... list goes on. smile.gif
FS thread : Custom Celica parts made to order + more
Click the image to visit my FB page
post Sep 18, 2013 - 1:54 PM
Box
Joined Feb 23, '12
From Warrior, AL
Would've been kind of hard to use SMD's in this instance. For one the curvature of the line would've made it a pain, and the fact the holes were drilled out and the LED's inserted would be more difficult with a SMD. Unless you baked open the light and could get SMD strips to fit into the crevice he used, that would be a little easier overall. The only thing I would've done differently on this install would've been to make a lot of arrays in series and wire them in parallel to greatly reduce the amount of resistors and soldering needed.
Looks cool and has a lot of possibilities. Would work great as a stop light or as a tail light. Kind of like the idea of using it as a stop light, really get people's attention.
This post has been edited by Box: Sep 18, 2013 - 1:58 PM
2001 Miata LS 5-speed
post Sep 18, 2013 - 2:24 PM
The_enD
Joined Apr 12, '13
From Bulgaria
QUOTE (Box @ Sep 18, 2013 - 9:54 PM) *
The SMD's can be cut every 5cm or every 3 LEDs (depends on the type tho) and then without any problems just connected to + and - wires. Additionally you can cut those 3 in and arrange them in whatever fashion as long as you keep the circuit the same as before (+-+-+-).
They are a lot smaller so the hole drilled for them will be too. They could of been mounted the same way he did with encased LEDs, just not taking up that much space and time soldering each.
post Sep 18, 2013 - 4:24 PM
Box
Joined Feb 23, '12
From Warrior, AL
The last time I saw a SMD LED strip the way they're spaced it would've needed cut after every diode for the curves on the light. I like the flexibility offered by individual LED's(rather SMD or traditional), but I also like the convenience of SMD LED strips for covering large areas instantly. Haven't looked lately, but it'd be nice to find a tightly spaced SMD LED strip.
post Sep 19, 2013 - 2:36 AM
yellowchinaman
Joined Aug 11, '08
From London
I bought a long roll or flexible LED strip which can be cut to any length in when I was planning on doing something similar. Personally I would have removed the lense and put a stip in for a cleaner look but this method would be easier.
post Oct 1, 2013 - 4:30 PM
KAOS
Joined Apr 18, '06
From Calgary, Canada
Innovative! I like!
post Oct 4, 2013 - 7:24 PM
M4ddoX
Joined Jun 3, '13
From Auckland, New Zealand
keen to see some photos of it fitted once its done. Looks pretty cool so far but I agree if I was attempt this I would use strip LED's
1997 White ST202
post Oct 4, 2013 - 7:59 PM
block
Joined Jul 27, '06
From Soda
I must admit, it looks damn good! Cant wait to see the finished product.
Lo-Fi Version Time is now: November 26th, 2024 - 10:27 AM
