> Flickering Dash LED's
post Sep 23, 2013 - 7:31 PM
M4ddoX
Joined Jun 3, '13
From Auckland, New Zealand
So after one side of my gauge had no lights I went and replaced them with blue LED's (these ones http://www.jaycar.co.nz/productView.asp?ID...p;form=KEYWORD). They worked fine for a while but now the middle and right one are flickering which is really annoying and distracting tonight. Does anyone know why this might be happening I would be very thankful smile.gif
1997 White ST202
post Sep 23, 2013 - 8:31 PM
richee3
Joined Jun 29, '08
From Denver
Very common thing. It's from varying wattage and in my personal experience, low quality LED's. I used to buy v-led's and occasionally use my dimmer and I had this problem frequently. I switched to Diode Dynamics LED's and stopped dimming them and haven't had a problem since.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Sep 23, 2013 - 9:10 PM
Box
Joined Feb 23, '12
From Warrior, AL
Do what I do and buy a pack of 100 LED's from China for like $3 and make all the bulbs yourself. Then whatever resistors you need are easily gotten from your nearest Radio Shack. Better, cheaper, and the pride of doing it yourself and saving a good chunk of change. Celebrate your savings with a case of lager. tongue.gif
2001 Miata LS 5-speed
post Sep 24, 2013 - 2:11 AM
rentaspace
Joined Sep 23, '12
From Australia
QUOTE (Box @ Sep 23, 2013 - 10:10 PM) *
Instead of using resistors, use a good quality voltage regulator. This will let the LEDs have exactly the needed voltage all the time. These are more expensive than bulk resistors though.
post Sep 24, 2013 - 4:30 AM
Box
Joined Feb 23, '12
From Warrior, AL
Resistors suffice, spec it out to 14.4V and you'll be fine.
post Sep 24, 2013 - 4:36 AM
rentaspace
Joined Sep 23, '12
From Australia
QUOTE (Box @ Sep 24, 2013 - 5:30 AM) *
That is also an option, but of you happen to get a bad batch or falsely advertised product; it won't help you tongue.gif
post Sep 24, 2013 - 4:34 PM
Box
Joined Feb 23, '12
From Warrior, AL
Just in the way faulty voltage regulators wouldn't help at all either. tongue.gif
post Sep 24, 2013 - 6:15 PM
rentaspace
Joined Sep 23, '12
From Australia
QUOTE (Box @ Sep 24, 2013 - 5:34 PM) *
post Sep 24, 2013 - 11:45 PM
Special_Edy
Joined Oct 29, '11
From Haltom City, Texas
I find that cheap chinese LEDs usually only fail due to poor soldering on my part. You can't apply heat to the leads for very long or it damages the semiconductor inside
post Sep 25, 2013 - 2:11 AM
Box
Joined Feb 23, '12
From Warrior, AL
I've actually been quite pleased with the ones I've bought from China. I have the eBay seller saved somewhere. Anyhow out of the 100+ you get I think there was only 1 dud. You buy 100 and you get a little over that, I suppose for that very reason.
post Sep 25, 2013 - 7:26 AM
rentaspace
Joined Sep 23, '12
From Australia
I am waiting for my resistors to arrive, total cost $8, which gave me 100 LEDs and 500 resistors smile.gif
post Sep 25, 2013 - 9:19 PM
Special_Edy
Joined Oct 29, '11
I paid $24 shipped for 1000 LEDs, maybe 14,000mcd.
DHGate.com
Also look at Mouser electronics for everything under the sun
post Sep 26, 2013 - 2:07 AM
Nihil
Joined Jul 17, '12
From Slovenia
Lo-Fi Version Time is now: December 3rd, 2024 - 10:23 PM
