> Toyota Celica tuuune up, faster rev up, faster acceleration, faster everything!
post Sep 26, 2013 - 4:26 PM
Clarkkent
Joined Sep 26, '13
From Finland
Heyo! I've got and Toyota Celica 1996 SS-III with 2.0 3SGE engine. Currently it has what ehm 177hp ~ 130kw, and I've been thinking of increasing it to 200hp. So theres 23 ponies to go. Last add up was an apexi cold air intake filter, dunno if it actually adds any hp, but anyway... it's under the hood now. laugh.gif
And please, if you guys have more hp's in your celica than stock, what did you do!? Money limit for me is around 900$, and now I need advises how to reach my goal.
This post has been edited by Clarkkent: Sep 26, 2013 - 4:27 PM
post Sep 26, 2013 - 5:09 PM
Rusty
Joined Nov 5, '07
From New Zealand
mine is 116.7Kw @ wheels / 156.5HP (Which is about what the beams puts out anyway) I don't trust the way UK people do their dyno's, so I don't read to much into their figures.
exhaust, there is a few options out there for our engine still, HKS hipower is a good option, as is the Kakimoto
cams + camgears
cams I would keep around the 22#deg @ 1mm valve lift
increase fund limit get a ecu
haltech platinum sport 1000. reasons: tidy install, can use all factory sensors & runs acis. see youtube install for more details
lastly check out the sticky thread above and go down to the 3S-GE section, lots of info there
post Sep 30, 2013 - 8:35 AM
Clarkkent
Joined Sep 26, '13
From Finland
How much cam gears actually affect to power? And will performance headers add any hp?
This post has been edited by Clarkkent: Sep 30, 2013 - 11:16 AM
post Sep 30, 2013 - 4:48 PM
Rusty
Joined Nov 5, '07
From New Zealand
Once you change the cam size you need to fine tune or optimise the cam timing to suit the new camshafts, that's where the cam gears come in.
The factory extractors/header are very good & flow very well, small gains to be made by removing the inside welds/porting them. The only reason IMO for changing them is when you increase the flow of the head, camshafts, valve springs, porting etc
Lo-Fi Version Time is now: November 23rd, 2024 - 3:28 AM
