> My first modifications on st205. Please advice
post Oct 9, 2013 - 6:59 AM
superhardware
Joined Oct 9, '13
From Georgia
this is my firs post on this forum. I am from Repulbic of Georgia and I want to say sorry for my English.
This is What I has: 1996 JDM ST205 with 80K milage.
this is what I already bought and going to swap it:
Greddy Emanage Ultimate with map pressure sensor
Garrett T04B Turbo
Custom manifold
Custom downpipe
Greddy boost controler.
Now my question is:
What WHP and BHP should I expect and what will be maximum safe power on stock engine?
Do I need to upgrade intercooler for 300WHP?
post Oct 9, 2013 - 5:39 PM
bsamps4
Joined May 16, '10
From Raleigh
It sounds like you went with the BIG modifications first without building your engine. I would have recommended "bolt-on helpers" for your stock set up first to see how you liked it, but you are going to need to make some big fuel upgrades to support the modifications that you have bolt. It will be good for over 300hp, but you should probably convert to front mount once you achieve over 320 at the wheels.
post Oct 10, 2013 - 8:43 AM
superhardware
Joined Oct 9, '13
From Georgia
can you tell me if ~350 BHP will be safe on stock internals and stock intecooler? mena power on engine, not on weel
thanks
post Oct 10, 2013 - 8:48 AM
bsamps4
Joined May 16, '10
From Raleigh
There are guys around her running 350 at the engine no problem on stock internals and water to air intercooler.
post Oct 10, 2013 - 8:49 AM
QUOTE (superhardware @ Oct 10, 2013 - 9:43 AM) *
thanks
Yes the motor and intercooler are fine at that power level, but just remember that it highly depends on how that emanage you have is tuned.
post Oct 10, 2013 - 10:25 AM
superhardware
Joined Oct 9, '13
From Georgia
has anyone swaped that kind of turbo in st205?
post Nov 27, 2013 - 4:56 AM
superhardware
Joined Oct 9, '13
From Georgia
1. manifold is done
2. turbo is attached
3. also attached front mount intercooler.
my car:
Garett T04B and Emanage ultimate:
Cooler:
new body kit - on top is mine, after body kit will looks like this:
we start to build Costum manifold with 450mm runners:
This post has been edited by superhardware: Nov 27, 2013 - 5:00 AM
post Nov 27, 2013 - 5:39 AM
Chanassa
Joined Nov 20, '13
From Norway
Nice! What kind of body kit is that?
------------------------------| White '97 Celica | Bought 01/11/13 | Sold: Never |------------------------------
post Nov 27, 2013 - 6:00 AM
superhardware
Joined Oct 9, '13
From Georgia
QUOTE (Chanassa @ Nov 27, 2013 - 6:39 AM) *
dont know smile.gif, Just sow St202 in in street with that kit, and offer 100 USD for it biggrin.gif
post Nov 27, 2013 - 7:50 AM
JoshuaM
Joined Mar 6, '12
From Brisbane, Australia
QUOTE (superhardware @ Nov 27, 2013 - 7:00 AM) *
That is just what is known as the TRD Sideskirts and TRD front and rear splitters / spats... however, as Rusty (moderator) has pointed out in one of the ultimate parts stickies it is in actual fact just one of the Toyota OEM optional extras kits.... but a good one smile.gif
And that second pic of the other car looks like a CF replica riser blocks with just the letters painted.
Looks good! (y)
post Nov 28, 2013 - 2:52 AM
Chovies
Joined Mar 1, '12
From Sydney, Aus
Everyone gets great st205 chances and Australia is stuck with a minimum 20grand for a decent one frown.gif
Listen, Like and Share my bands page on facebook !!!
https://www.facebook.com/AwakenedAus
post Nov 28, 2013 - 4:43 AM
delusionz
Joined Feb 11, '08
From Auckland, New Zealand
Hi nice car.
Nice turbo package. You will be limited by the factory injectors to around 350hp @ engine, 280-300hp @ 4wheels
The stock engine internals can handle this just fine, and the small size of that turbo means the limits of the stock engine and stock fuel system will be reached near the limits of that turbo (this makes a good match for now, but you may regret this in the future when your desire for power increases)
I recommend using a Gen4 Intake manifold to complete your front mount setup
this is mine
This post has been edited by delusionz: Nov 28, 2013 - 4:54 AM
Mike W
269awhp / 273ft-lbs
post Nov 28, 2013 - 8:55 AM
superhardware
Joined Oct 9, '13
From Georgia
I know that stock injectors cant do more, but what I dont know is - will my fuel pump be enough for 350HP on engine?
post Nov 28, 2013 - 11:24 AM
mkernz22
Joined May 10, '10
From MA
QUOTE (superhardware @ Nov 28, 2013 - 8:55 AM) *
have you replaced the fuel pump yet? if not, you'll probably hit fuel cut very quickly.
you should upgrade to a walboro 255lph (liter per hour) one
post Dec 8, 2013 - 1:43 PM
superhardware
Joined Oct 9, '13
From Georgia
This post has been edited by superhardware: Dec 8, 2013 - 1:44 PM
post Dec 16, 2013 - 10:14 AM
superhardware
Joined Oct 9, '13
From Georgia
Hello,
Can anybody tell me how to disable cooler pump error? there is no more water to air inter cooler inside and I god check engine... biggrin.gif
post Dec 16, 2013 - 12:12 PM
sentraman
Joined Dec 10, '13
From portland,or
Interesting manifold design, but is that 16ga you are using?
post Feb 9, 2014 - 5:13 PM
superhardware
Joined Oct 9, '13
From Georgia
in my country therr is only ime dyno, ant it is 2 wheel drive
I have finaly finished my first setup and today was dyno tuning day. as dyno is 2 wheel drive soluton was to remove drive shaft fot rear wheels, but it was wrong way: in firs gear it was running like neitral, the same was on second gear, on third it was look like normal and the same in forth gear but when we start tuning emanage and when power was incrasing - engine was runing on high perfomance, but on whell there was no power...
any idea???
maximum dino rsult was 300 bhp on 0.7 bar..... but i am shure there was more power on this pressure but power was loosing in gear....
This post has been edited by superhardware: Feb 9, 2014 - 5:16 PM
post Feb 10, 2014 - 4:25 AM
superhardware
Joined Oct 9, '13
From Georgia
300 bhp was without ignition setup....
Lo-Fi Version Time is now: February 20th, 2025 - 1:56 AM
