Lost power, its a 7afe |
Oct 11, 2013 - 9:10 PM |
Enthusiast Joined Oct 11, '13 From 103062 Currently Offline Reputation: 0 (0%) |
it got slow over the time but everything is in good conditions any tips??
Oct 11, 2013 - 9:26 PM |
Slipping clutch, or auto, maybe? Eh, have you done a tuneup lately? Perhaps lost compression, so I'd check that.
This post has been edited by Box: Oct 11, 2013 - 9:27 PM -------------------- 2001 Miata LS 5-speed
Oct 11, 2013 - 10:46 PM |
Oct 11, 2013 - 10:54 PM |
Locals Auto Zone or Advance should have a compression gauge. You screw them into the head just like you would a spark plug, and turn the motor over a few times. Then that gives the compression in psi, gives a good idea of the engine's health. If the compression is low could be a blown ring or bad valves.
Oct 11, 2013 - 11:56 PM |
Locals Auto Zone or Advance should have a compression gauge. You screw them into the head just like you would a spark plug, and turn the motor over a few times. Then that gives the compression in psi, gives a good idea of the engine's health. If the compression is low could be a blown ring or bad valves. oh okay thanks for the help and do u know about how much psi it should be in? |
Oct 12, 2013 - 12:31 AM |
I want to say the minimum is 140 psi, but 180-200 would be ideal.
This post has been edited by Box: Oct 12, 2013 - 12:31 AM -------------------- 2001 Miata LS 5-speed
Lo-Fi Version | Time is now: January 15th, 2025 - 5:07 AM |
