Update on NEW Wiring Harnesses for 3SGTE, 4AGE, 4AGZE, etc |
Oct 15, 2013 - 3:24 PM |
Enthusiast Joined Mar 31, '04 From Summerville, SC Currently Offline Reputation: 5 (100%) |
Hi everyone! I know I haven't been around much and I hope you've all be doing great. We've been super busy here at Tweak'd Performance and one thing that I've FINALLY taken some time to set up is building brand NEW 3SGTe, 4AGE and 4AGZE harnesses for the Celica (or anything else for that matter). Of course you know we've been doing plug and play wiring conversions nearly 10 years now, but there are times when nothing but a brand new harness will do.
We can build these for the 20v Silvertop (auto or manual ECU), 20v Blacktop, 4AGZE AE92, 4AGZE AE101, and 2nd/3rd/4th (ST215) 3SGTE engines into any chassis. The engine harness itself is completely brand new, that means new connectors, terminals, wire, etc. The only thing we need for your original Celica harness are the body plugs that connect to the body harness/fusebox. Our standard looming method is a huge upgrade over factory, braided sleeving on all branches and split braided sleeving for the main section of loom. These harnesses are tucked, look great, and are also available with a MILSPEC firewall connector for anyone looking to go for that really high-end look. Besides building these harnesses for any revision of the OEM Toyota ECU, we can also build it straight to ANY standalone EMS that you want to use, for no extra charge. In fact we keep the ECU connectors IN STOCK here for the AEM 30-6050, Haltech, Motec, Vipec, and ProEFI ECUs. Turnaround time for custom harnesses is about one week, we strive to keep OEM-style harnesses in stock and ready to ship. Here are a few pics for your enjoyment. New harnesses start at $650 - $800 depending on the version. You can run any injectors, sensors, etc. We have GM 3-bar map sensors, AEM map, AEM/GM IAT, Bosch injectors, ID2000, ID1000, GM LQ9 coilpacks, etc etc etc all in stock. Generally there is no extra charge for changing what ECU/EMS you're running or injectors, if you need a LOT of custom work done like adding and moving things around, it may cost an extra $100 - $200. You can also run a flex fuel sensor (we have the GM/Continental connector in stock), fuel pressure, wideband 02 (we carry the LSU4.9 connectors in stock), boost solenoid, etc. Anything you want deleted or moved just let us know. Mil-Spec harness example (2JZ into Supra): 4th Gen 3SGTE ST215 into AW11: Closeup of our standard looming: Comments and questions are welcome! Also please like our facebook page at www.facebook.com/tweakdperformance/ -Dr. Tweak, Tweak'd Performance LLC 800-533-6775 www.tweakdperformance.com -------------------- -Dr Tweak, 6GC's resident engine swap wiring expert extraordinaire Click here to see my swaps drtweak@phoenixtuning.com |
Oct 15, 2013 - 3:47 PM |
Enthusiast Joined Jul 12, '08 Currently Offline Reputation: 5 (100%) |
How are your eyes not bleeding from all that wire work?? Looks amazing
Oct 15, 2013 - 11:06 PM |
Definitely good looking work
-------------------- 95 gt coupe, v6 swap weekend toy
Oct 16, 2013 - 6:41 AM |
Those harnesses are a thing of beauty, bro, you and cam are doing some great work on em!
13.6@108MPH, 5SFTE Powered |
Oct 16, 2013 - 9:20 AM |
nice amphenol connectors. how are you handling pins that are on shielded wires like the knock, cam, and crank sensors? are you using a coax pin and carrying the shield through or grounding the shield the the backshell?
Oct 16, 2013 - 10:47 AM |
Thanks everyone!
Smaay, the shielded circuits are grounded at the backshell. Joshua -------------------- -Dr Tweak, 6GC's resident engine swap wiring expert extraordinaire Click here to see my swaps drtweak@phoenixtuning.com |
Oct 16, 2013 - 11:28 AM |
Enthusiast Joined Jan 16, '12 From 860, ct Currently Offline Reputation: 0 (0%) |
That's some quality work.
Will you be offering 1MZ harnesses brand new as all or are those still converted harnesses because these things look beautiful. |
Had this been posted before I would've probably had you make my MS3X's harness...
-------------------- 1993 Celica GT Coupe - sold
1994 Celica GT Liftback |
Oct 16, 2013 - 11:36 AM |
very good, I love working in aerospace, i have access to tons of these connectors with all types of configuration. I was going to build myself one of these for my Supra. Its nice to see this as an option.
Oct 17, 2013 - 4:43 PM |
That's some quality work. Will you be offering 1MZ harnesses brand new as all or are those still converted harnesses because these things look beautiful. Currently we don't have 1MZ harnesses new just because the demand is still fairly low. We *could* do it and may if they become popular enough. Doc -------------------- -Dr Tweak, 6GC's resident engine swap wiring expert extraordinaire Click here to see my swaps drtweak@phoenixtuning.com |
Oct 17, 2013 - 5:41 PM |
That's some quality work. Will you be offering 1MZ harnesses brand new as all or are those still converted harnesses because these things look beautiful. Currently we don't have 1MZ harnesses new just because the demand is still fairly low. We *could* do it and may if they become popular enough. Doc Oh they will. -------------------- 2001 Miata LS 5-speed
Lo-Fi Version | Time is now: November 25th, 2024 - 2:46 PM |
