Reducing Understeer |
Oct 22, 2013 - 8:35 AM |
Enthusiast Joined Apr 18, '06 From Calgary, Canada Currently Offline Reputation: 37 (100%) |
I'm looking for some advice. The engine is almost back in the car, and I then need to finish the chassis upgrades.
I have a ST front sway bar to install and my friend seems to think that if I remove the sway bar altogether and NOT install the ST bar, that will significantly remove any understeer. <- I gave him one of these. Doesn't make much sense to me to completely remove it; the new REAR sway bar is installed and set to stiff. But I can't see this car having so much HP that understeer would be affected at all... Squash this inner turmoil for me. ... and GO! -------------------- |
Oct 22, 2013 - 8:50 AM |
Enthusiast Joined Mar 6, '12 From Brisbane, Australia Currently Offline Reputation: 6 (100%) |
Lots of threads on this.... somewhere, lol Rear stiffening = less understeer from everything I've been told. Make sure you have decent tyres before you spend money on bracing though. -------------------- SOLD :( 1997 ST204 Celica ZR -----> See it here on 6GC! 2013 October Celica of the Month XD Now: '00 NB8B Mazda MX5 -----> See it here in off topic! |
Oct 22, 2013 - 8:56 AM |
I disconnected my frontsway bar in my MKIV Jetta Turbo....its pretty common in that group.
Good poly bushings in the control arms, quality tires, a bit of negative camber should definitely help |
Oct 22, 2013 - 2:34 PM |
Enthusiast Joined Aug 29, '02 From Lake Orion, MI Currently Offline Reputation: 6 (100%) |
I'm looking for some advice. The engine is almost back in the car, and I then need to finish the chassis upgrades. I have a ST front sway bar to install and my friend seems to think that if I remove the sway bar altogether and NOT install the ST bar, that will significantly remove any understeer. <- I gave him one of these. Doesn't make much sense to me to completely remove it; the new REAR sway bar is installed and set to stiff. But I can't see this car having so much HP that understeer would be affected at all... Squash this inner turmoil for me. ... and GO! I'm curious... under what conditions are you experiencing understeer? This post has been edited by qatar11: Oct 22, 2013 - 2:38 PM -------------------- -Mike
mjcoury@gmail.com Team Reynolds Style Celica Blog Celica Wiki It will take him a moment to realize that he's about to make a 180 degree turn at speed, but you will be ready for it. Brace for the g's, and fast heel-toe work. |
Oct 22, 2013 - 3:18 PM |
Oct 22, 2013 - 3:33 PM |
to reduce understeer do some or any of these upgrades
FRONT: 3pt strut brace, high perf tyres, -1deg neg camber, lowering REAR: rear swaybar, cheap tyres, raise rear, neutral 0 camber -------------------- Mike W
Oct 22, 2013 - 3:35 PM |
Enthusiast Joined May 31, '11 From Rochester, NY Currently Offline Reputation: 5 (100%) |
Want less under steer? Raise the rear! By giving the car a slight but of "rake" you effectively raise the center of gravity, causing the rear to come around instead of the front. You also want a stiffer sway bar in the rear with stiffer end links (I recommend MOOG because of how thick they are) and urethane bushing on the rear bar. A bit of camber and you can actually oversteer in a Celica.
-------------------- 1994 Toyota Celica GT-S 5S-FE 190k Miles. Project car 1992 Toyota Celica GT 5S-FE 170k Miles. Daily driver/beater 1999 Toyota Camry LE 5S-FE 216K Miles. RIP You will be missed. *ASE Certified General Manager |
Oct 22, 2013 - 4:26 PM |
I heard removing front sway bar makes hard braking unstable. Get suoerstrut suspension
Oct 22, 2013 - 4:30 PM |
or fix your driving. if your car cant turn? pull the e-brake.
fix your driving line so youve already made some of the turn before accelerating, then you can create a weight transfer -------------------- Mike W
Oct 22, 2013 - 4:53 PM |
Sorry, I think the point of this topic wasn't clearly communicated.
I wanted to tell my buddy that he was out of his mind. (a) not RACECAR (b) never will be driven to the extremes that I would ever experience oversteer/understeer © the suspension goodies were purchased all at the same time with the twos r us end links, and adjustable Tokicos at a great price. (so I'd like to install them all anyways, iiregardless of the usage they'll receive) (d) I would maybe AutoX the car later in life Basically, I wanted the suspension guru's to give me some technical facts that I could take to him and say; I'm putting the front sway bar on, I will never see understeer on this car, etc etc etc. I've pretty much just answered my own request, but I like to hear more information about reducing understeer anyways, so keep it going! There have been some good pointers so far. This post has been edited by KAOS: Oct 22, 2013 - 4:54 PM -------------------- |
Oct 22, 2013 - 4:58 PM |
oh yeah, i didnt properly read the first post.
Yes, install both, set front to normal, set rear to stiff, or if in doubt... install both on the middle setting -------------------- Mike W
Oct 22, 2013 - 5:46 PM |
The link I posted /thread
Oct 22, 2013 - 6:26 PM |
Our cars hardly understeer at all... even when mine was stock it would barely understeer. You also need to know how to corner properly; like when to brake, when to coast, when to get on the gas, and also you need to have a nice line through a corner. Obviously, if you cut the wheel sharp and stomp on the gas, you'll get a bunch of understeer lmao
With my setup; front 3pt strut bar rear 2pt strut bar interior harness bar coilovers all around about -1.7 to -1.9 camber in the front about -3 to -3.5 of camber in the rear (didn't plan for that to happen, just did when I installed my coilovers) bridgestone potenza re-760 sport tires I don't get any understeer at all. No oversteer either, but I can make the rear end kick a little bit lol And to answer your question, if you install the front ST sway bar, it will help with the understeer. But like you said, NOTRACECAR, so you shouldn't even be worried haha |
Oct 23, 2013 - 6:24 AM |
Also, as a general rule; passenger cars are designed to understeer. It's a safer, "loss of car control" scenario than say... some snappy oversteer.
about -3 to -3.5 of camber in the rear (didn't plan for that to happen, just did when I installed my coilovers) Holy crazy tire wear, Batman! -------------------- -Mike
Oct 23, 2013 - 9:16 AM |
Camber doesn't wear tires down. Alignment and toe issues is what kills tires.
Oct 23, 2013 - 9:42 AM |
Camber doesn't wear tires down. Alignment and toe issues is what kills tires. sorta right/wrong. Technically this is normal wear just localized on the inside tread area This post has been edited by Tigawoods: Oct 23, 2013 - 9:44 AM -------------------- 1995 GT::::Diffusing the Situation エキサイティングカーレーシングチーム! march 2010 COTM : 6GC feature 2014 : january 2015-2016-2018 COTM |
Oct 23, 2013 - 9:57 AM |
Also, as a general rule; passenger cars are designed to understeer. It's a safer, "loss of car control" scenario than say... some snappy oversteer. about -3 to -3.5 of camber in the rear (didn't plan for that to happen, just did when I installed my coilovers) Holy crazy tire wear, Batman! Well I've only had them on for the spring-fall so there really isn't too much odd wear. It really helps with cornering though because when you turn to either side the tire will press down more evenly on pavement and will become closer to 0 degrees of camber, which makes a better contact to the ground. Where as if you're around 0 to -1 degree of camber, depending on the corner, the wheel might start to positive camber, which could be bad because you run the possibility of losing contact on the inside of the tire. I've only read up on the whole camber thing a little bit so that's what I took from it so far, hoping to read up more in the near future, but if I'm wrong, please feel free to correct me on it. |
Oct 23, 2013 - 10:17 AM |
Camber doesn't wear tires down. Alignment and toe issues is what kills tires. sorta right/wrong. Technically this is normal wear just localized on the inside tread area Sorry RabidTRD, I cannot agree with this. As a general rule, there is very little downside to dialing in lots of negative camber... other than balancing out tire wear. All alignment decisions will effect the wear of a tire. -------------------- -Mike
Oct 23, 2013 - 12:39 PM |
Enthusiast Joined Sep 27, '10 From pittsburgh Currently Offline Reputation: 4 (100%) |
If your front tires arent sliding you arent understeering. If your rear tires aren't sliding you arent oversteering. You just need to turn the wheel and take better lines.
-------------------- -93 Rx7, Turbo 6.1L v8, 725rwhp/760rwtq
-95 Celica GT Rally Car - 3sge/AWD -10 F150 Always buying stock wheels... PM me if interested in selling. |
Oct 24, 2013 - 7:09 AM |
If your front tires arent sliding you arent understeering. If your rear tires aren't sliding you arent oversteering. You just need to turn the wheel and take better lines. Hitting the wall at speed head on = understeer Hitting the wall at speed ass end first = oversteer -------------------- -Mike
Lo-Fi Version | Time is now: November 28th, 2024 - 8:51 PM |
