ECU removal |
ECU removal |
Oct 23, 2013 - 2:06 AM |
Moderator Joined Nov 5, '07 From New Zealand Currently Offline Reputation: 3 (100%) |
Well since getting the Tom's ECU, I've had a look around where the ecu sits & on toyodiy.
Sits within 2 brackets & has an external relay on one side. So the easiest way would be to bring the whole thing out in one go. Did you have to remove any interior trim pieces or can you get away with not removing any? Also remember its an ST202 so RHD, passengers side = L -------------------- |
Oct 23, 2013 - 2:30 AM |
Enthusiast Joined Jan 19, '11 From Paraguay, Winchestertonfieldville Currently Offline Reputation: 1 (100%) |
I believe mine ws behind the radio on my gtfour
Oct 23, 2013 - 2:32 AM |
yes I know where it is, I'm trying to remove it to put this in
Oct 23, 2013 - 2:54 AM |
Enthusiast Joined Feb 3, '06 From Czech Republic (Europe) Currently Offline Reputation: 56 (100%) |
-------------------- No more replicas... This is evolution... This is SS-four :)
________[Featured Celica of 6gc.net @ 2010]_________ |
Oct 23, 2013 - 4:05 AM |
I was able to remove mine by pulling the carpet down on both sides of the console, then a little wiggle work to maneuver it out.
Oct 23, 2013 - 4:10 AM |
Enthusiast Joined Oct 19, '13 From North Italy Currently Offline Reputation: 0 (0%) |
Oct 23, 2013 - 3:14 PM |
thanks richee
stalker76, you will never find one as they didn't make one for the redtop beams -------------------- |
Oct 23, 2013 - 7:46 PM |
Enthusiast Joined Dec 11, '04 From USA Currently Offline Reputation: 12 (83%) |
Curious to see what TOMS ecu does . Sure my Imec tuned 3sge ecu similar
Sadly i will never know as not using ecu or motor in anything ever. Can't wait for dyno results . This post has been edited by FORGMANN: Oct 23, 2013 - 7:47 PM -------------------- Old guy with the toys
95 ST205 WRC (the real deal) 94 MR2 HARDTOP Supercharged 2GR/6SPD 22 owned |
Oct 23, 2013 - 8:18 PM |
I emailed the I-Mec/I-Code group awhile ago when you posted yours to learn more about it. I'm sure the reflashed/ plug in ecu's Tom's TECS II, I-Mec, C-One Power ECU, Biltz Access etc do the same stuff replaced daughterboard to allow changes to be made, and is optimised to the owner and mods they have.
QUOTE セリカST202用 アイメック製ECUは、点火、 燃料調整、スピードリミッターカット 3種類が変更してあります。 Thank you for your e-mail. We announce you the contents of the IMEC (change & contents are the same as icode in the name of four years before & company)ECU for Celica ST202. 1) Ignition timing adjustment 2) Fuel increase in quantity. 3) speed limiter cut of 180km. ... not sure if the speed cut is completely removed or just moved up higher like the HKS SLD -------------------- |
Oct 24, 2013 - 4:50 AM |
Oct 24, 2013 - 4:17 PM |
1. has the ability to run your engine - vvti
2. Your tuner who knows & is familiar the ecu that will do the maps etc I've heard of people using the Apexi Power FC from the 1ZZ-FE for the beams, as they're both similar to each other. Chances are you'll get a standalone ecu, which will cost a bit, plus wiring/install and then on top of that more dyno/tuner time to set up all the vvti changes -------------------- |
Oct 24, 2013 - 5:18 PM |
Thanks for the advice Rusty!
Obviously I know that everything would cost ... but the money is not a problem ... the only problem is that here in Italy .... not familiar with the celica ... figured engines Beams: D For this I registered on 6GC, surely you are much more than any enced mechanic here in the area. I've heard that on Beams use the Apexi Power FC |
Oct 24, 2013 - 7:14 PM |
Enthusiast Joined Mar 16, '09 From New York Currently Offline Reputation: 23 (100%) |
i couldnt get mine out for the life of me from the side lol. I did it a long time ago, but remember I had to pull out the whole "shifter console". but i mean thats like 4 screws, easy in and out either way
Oct 26, 2013 - 9:29 AM |
Enthusiast Joined Sep 6, '12 From Holland Currently Offline Reputation: 1 (100%) |
For my 7AFE ECU it was really easy. Pull the carpet down. Unscrew the 3 bolt, wiggle a bit and pull it out. Ow yeah, first unplug the connectors
But normally it's a really easy (10 min) task. This post has been edited by onnaj: Oct 26, 2013 - 9:29 AM -------------------- |
Lo-Fi Version | Time is now: December 3rd, 2024 - 8:14 PM |
