Whats your tire size? |
Apr 24, 2008 - 12:15 AM |
Enthusiast Joined Feb 3, '04 From West Windsor, NJ Currently Offline Reputation: 3 (100%) |
I'm considering buying a set of 16x7 rims that would come with 245/50/16 tires... These should fit on a Celica, right? (my car is lowered, in case that matters).
edit: my current tires are 205/50/15... I like the comfort, but not the handling. This post has been edited by Rider: Apr 24, 2008 - 12:17 AM |
Apr 24, 2008 - 12:16 AM |
Enthusiast Joined May 12, '06 From Wilmington, NC Currently Offline Reputation: 45 (100%) |
QUOTE(chrisalphonsus @ Apr 23, 2008 - 9:30 PM) [snapback]667568[/snapback] can 245/40/18 and a 9 inch wide wheel require a lot of modifications to put on as my car is lowered 1 inch , please help as i might have just got ripped off by someone who vouched it will fit what's the offset? (it should be stamped somewhere on the wheel, usually on the back of the spokes.) it's gonna be hard to fit them. you'd need an offset somewhere around a 25-35, probably about 30. Then, you're wheels are gonna stick outside your fender about 10-20mm so you'll need to roll the fenders. it also might be much easier to fit with a 245/35/18 tire. -------------------- 94 GT - Sold -------- 69 Pontiac Lemans - Sold 88 Alltrac - Sold ---- 04 WRX - Sold 00 GT-S - Sold ------ 91 Miata - project/drift car 95 GT - Sold -------- 96 GT - New Daily Drive |
Apr 24, 2008 - 12:30 AM |
The offset on the rims I was asking about is 38 if that matters.
This post has been edited by Rider: Apr 24, 2008 - 12:35 AM |
Apr 24, 2008 - 12:48 AM |
Enthusiast Joined Oct 7, '06 From wyomissing pennsylvania Currently Offline Reputation: 2 (100%) |
i believe they should fit.
with my old wheels which i think are a 30-35 offset? maybe even 28 im not sure.. i mocked up a 235 35 18 tire and it fit very well, i was gonna get some 235 40 18's and rock them 245 40 18 will come close up front, but i wouldnt see any problems as long as you arent smashing bumps while turning -------------------- you know why they put sheep at the edge of a cliff.... that way they push back!
(2:27:32 AM) edit: please f*cking work, f*ck, sh*t, piss (2:28:08 AM) edit: that did the trick |
Apr 26, 2008 - 1:20 PM |
i have 185/70/14 the factory size tires.
on the side panel of the door it says cold tire invlation should be at 29 in front and 29 in the back, would 33 psi in the front and back do anything to the tires This post has been edited by BonzaiCelica: Apr 26, 2008 - 1:21 PM -------------------- Group buy to replicate Narrow E series transaxle parts
Apr 26, 2008 - 2:11 PM |
QUOTE(BonzaiCelica @ Apr 26, 2008 - 11:20 AM) [snapback]668407[/snapback] i have 185/70/14 the factory size tires. on the side panel of the door it says cold tire invlation should be at 29 in front and 29 in the back, would 33 psi in the front and back do anything to the tires look on the side of the tire for the max inflation pressure and don't go past that! if you notice the tire starts wear more on the middle than on the side, then it's got too much air. anf if it wears faster on both sides than the middle, it's under inflated. (if it wears on only one side, you need an alignment) -------------------- 94 GT - Sold -------- 69 Pontiac Lemans - Sold 88 Alltrac - Sold ---- 04 WRX - Sold 00 GT-S - Sold ------ 91 Miata - project/drift car 95 GT - Sold -------- 96 GT - New Daily Drive |
Apr 27, 2008 - 1:06 AM |
QUOTE(6strngs @ Apr 26, 2008 - 2:11 PM) [snapback]668416[/snapback] QUOTE(BonzaiCelica @ Apr 26, 2008 - 11:20 AM) [snapback]668407[/snapback] i have 185/70/14 the factory size tires. on the side panel of the door it says cold tire invlation should be at 29 in front and 29 in the back, would 33 psi in the front and back do anything to the tires look on the side of the tire for the max inflation pressure and don't go past that! if you notice the tire starts wear more on the middle than on the side, then it's got too much air. anf if it wears faster on both sides than the middle, it's under inflated. (if it wears on only one side, you need an alignment) oh okay ya it says max 44psi alright thank you -------------------- Group buy to replicate Narrow E series transaxle parts
Aug 14, 2008 - 1:33 PM |
Enthusiast Joined Jul 2, '06 From Shrewsbury, ma Currently Offline Reputation: 5 (100%) |
does anybody know if 225/50 16's will rub on a lowered car??? offset should be 35
Aug 14, 2008 - 4:13 PM |
Enthusiast Joined Feb 24, '07 From Oahu, Hawaii Currently Offline Reputation: 23 (100%) |
225 isnt that for 7.5-8.5in. wide rims?????? why!?!?!?!?! i get awesome handling with my new 205/45/16 91V (i think) tires...........oh they're Toyo Proxies 4s
-------------------- I don't normally drive fast, but when I do its on a curvy section of this island
Aug 14, 2008 - 4:18 PM |
Enthusiast Joined Jun 21, '08 From Naples, FL Currently Offline Reputation: 0 (0%) |
Aug 14, 2008 - 4:34 PM |
225 isnt that for 7.5-8.5in. wide rims?????? why!?!?!?!?! i get awesome handling with my new 205/45/16 91V (i think) tires...........oh they're Toyo Proxies 4s ya thats right... I have a 7.5 inch wheel thats goin on... I jus didnt know if n e body has tried that or knew if it would hit, cuz if I need 2 use a spacer it might look wierd |
Aug 14, 2008 - 5:41 PM |
if you're gonna use a spacer read that "things to know about spacer thread" for your safety
Aug 14, 2008 - 6:18 PM |
Enthusiast Joined Apr 15, '07 From Fort Worth, TX Currently Offline Reputation: 12 (100%) |
Falken FK452's, 205/50/16 on GTS wheels.
This post has been edited by GotToyota: Aug 20, 2008 - 8:41 AM |
Aug 14, 2008 - 7:50 PM |
does anybody know if 225/50 16's will rub on a lowered car??? offset should be 35 they should fit. maybe some slight rubbing on the fender plastics but no big deal. QUOTE (808celica) 225 isnt that for 7.5-8.5in. wide rims?????? why!?!?!?!?! i get awesome handling with my new 205/45/16 91V (i think) tires...........oh they're Toyo Proxies 4s you can fit a 225 on a 7 inch wheel. just not any wider. I had a 6gc come into my work the other day with 225/50/15's on the stock GT wheels. that's the tire size I was gonna run so I could get better traction with my 5sfte before I got the 17's and did 225/45/17's on a 8 inch wheel. -------------------- 94 GT - Sold -------- 69 Pontiac Lemans - Sold 88 Alltrac - Sold ---- 04 WRX - Sold 00 GT-S - Sold ------ 91 Miata - project/drift car 95 GT - Sold -------- 96 GT - New Daily Drive |
Aug 14, 2008 - 9:59 PM |
Enthusiast Joined Dec 15, '02 From Tasmania(Australia) Currently Offline Reputation: 0 (0%) |
225/40 18" although the rims are 8.5" so i could run a 245 or bigger, but this keeps the right rolling diameter.
-------------------- ST205 Group A Rallye GT-Four, #61 of 77............600hp GT3582r
GRX133 Toyota Mark X 350s |
Aug 15, 2008 - 5:07 AM |
Enthusiast Joined Aug 12, '08 From bangalore,india Currently Offline Reputation: 0 (0%) |
EAGLE F1
215/40 R17 |
Aug 17, 2008 - 7:28 AM |
225/40/17 ZR Nitto Xtreme 555
This post has been edited by trdproven: Aug 17, 2008 - 7:30 AM -------------------- 94 Celica GT
Aug 17, 2008 - 8:33 AM |
Enthusiast Joined Nov 7, '06 From Houston, Tx Currently Offline Reputation: 17 (100%) |
two oh fi/ fitty/ sisteen hankook V4ES
-------------------- -Alex {](O_o)[}
1993.5 Toyota Supra ....with stuff.... ....sorta broken.... 1998 Toyota Celica ....this one, too, has stuff.... ....broken....yeah...definitely broken.... |
Aug 17, 2008 - 12:24 PM |
Enthusiast Joined Mar 24, '06 From Aloha, Oregon Currently Offline Reputation: 5 (100%) |
225/45 ZR17 Falken fk452
Aug 20, 2008 - 8:43 AM |
To you guys with the 225/45/17, why do you like it as opposed to the 215/45/17?
I have the Scion TC wheels, and I'm wondering if it's worth the extra money to get the 225's. What's the advantage of these as opposed to the 215's? I know the bigger tires will cost more, and I'm trying to save as much money as possible at this point. |
Lo-Fi Version | Time is now: November 27th, 2024 - 5:23 PM |
