> coolant leak
post Oct 25, 2013 - 8:25 PM
codybellenbaum
Joined Sep 16, '13
From los angeles, CA
So i finally found the region where im leaking coolant, but it doesnt make sense because there arent any hoses around there. after driving 5 miles down the free way at 70 i stopped and saw that there was alot of water being sprayed under the battery around onto the driverside wheel well. the only thing that i see involved with the cooling system around there is the radiator reservoir.. i dont see any cracks though and it holds water. does any pressure go into it? what could be leaking in that area? 1996 2.2 L
post Oct 25, 2013 - 11:57 PM
ILoveMySilly97
Joined Mar 8, '12
From Hanford/Fresno, Ca
Is your reservoir full? If it is then it might just be overflowing and it must've poured out of the overflow hole at the top of the reservoir neck. If not that go ahead and check all the hoses and the radiator just in case.
I take that back. Check all your hoses. Start from the upper radiator hose, inlet/outlet heater hoses, bypass hose, and TB hose.
post Oct 26, 2013 - 1:30 AM
codybellenbaum
Joined Sep 16, '13
QUOTE (ILoveMySilly97 @ Oct 26, 2013 - 12:57 AM) *
no the reservoir isnt full, its not coming out the overflow. its a leak below the battery shelf i just dont see any thing it could be leaking from...
post Oct 26, 2013 - 2:18 AM
ILoveMySilly97
Joined Mar 8, '12
Check the hoses I listed. More than likely its your upper radiator hose or radiator.
post Oct 27, 2013 - 7:49 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
check the hoses to the firewall
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Oct 28, 2013 - 3:22 PM
nics
Joined Feb 15, '08
From Royal Oak, MI
QUOTE (codybellenbaum @ Oct 25, 2013 - 6:25 PM) *
You might have an internal leak. You mentioned that the water is being sprayed on the side and under the battery. If you haven't noticed, the coolant reservoir has a hole on the neck, I assume that the water was going out there. The head gasket may be going out or a hole on the block that the exhaust gases is pushed into the water jackets then to the cooling system then to the radiator then the extra water/pressure goes into the reservoir and overflows.
God made man....
Everything else...
Made in China
post Oct 28, 2013 - 7:52 PM
Chicago-gt4
Joined Oct 28, '13
From Chicago il
QUOTE (codybellenbaum @ Oct 25, 2013 - 9:25 PM) *
if its leaking by the coolant res! It means that there is air in your coolant system and its gushing out of the res tank! So bleed your coolant system if it happens again your head or head gasket is sucking air pockets into the coolant system!
Lo-Fi Version Time is now: November 25th, 2024 - 8:47 PM
