> project - convert RHD ST205 to LHD - Help!
post Oct 26, 2013 - 2:15 AM
EdinR-DrugB
Joined Oct 25, '13
From Plovdiv,Bulgaria
Dear friends,
I am starting project to convert RHD ST205 GT4 to LHD.
I have some questions about the suspensions of the GT4,everything alls is clear for me but the suspension from my donor(ST202) is different - the front drive shaft and the front steering gear and some other things they are just different!?
Please anyone, help me to fix this problems?
Thanks in advance
This post has been edited by EdinR-DrugB: Oct 26, 2013 - 2:16 AM
post Oct 26, 2013 - 2:32 AM
Neon90424
Joined Jan 19, '11
Its superstrut. Why would you change it
post Oct 26, 2013 - 2:42 AM
JoshuaM
Joined Mar 6, '12
From Brisbane, Australia
Some cars have 'Macpherson' strut suspension and others have 'Super Strut' suspension. Also, it must be noted that suspension components are NOT the same between FWD and AWD models.... they may fit (but I can't confirm this), however the spring rates are different given the different weight of the vehicle.
Should be a great project though... where are you from and do you have any pictures? smile.gif
post Oct 26, 2013 - 2:53 AM
EdinR-DrugB
Joined Oct 25, '13
donor is also Super strut suspension but the front drive shaft is different ... looks like ST202 but check manual ... its different.
i am from bulgaria
pictures soon
post Oct 26, 2013 - 3:06 AM
LED-BOY
Joined Oct 20, '09
From England/Latvia
QUOTE (EdinR-DrugB @ Oct 26, 2013 - 3:15 AM) *
Dear friends,
Thanks in advance
I'm sorry, that in Russian, but here's a list of what is needed for this process from AT200-ST-202 ( you can translate it ):
1 - рулевая рейка со всеми тягами
2 - подрамник
3 - передняя панель
4 - штанга под панелью
5 - бардачок.
6 - центральная консоль
7 - пластик низа панели над ногами водителя
8 - пластик вокруг замка зажигания
9 - ручку ручника
10 - все кронштейны под консолью
11 - печка ( все три части )
12 - механизм дворников
13 - сами дворники
14 - пластмасса, которая закрывает дворники около лобового стекла
15 - мотор дворников
16 - ручки поворотников и дворников слева-справа от руля
17 - все три педали
18 - педаль отдыха для левой ноги
19 - ковёр
20 - шумка под ковром
21 - передние провода, которые находятся под панелью
22 - провода в панели
23 - трос багажника и люка бензобака
24 - ручки открывания багажника и бензобака
25 - замок капота
26 - два кронштейна от компьютера движка
27 - клапан на шланге антифриза со стороны моторного отсека
28 - моторный щит с частью стаканов
29 - зеркала наружные
30 - центральная пластмасса, в которую ставится магнитола
31 - пластик вокруг ручки коробки передач
www.celica-club.lv
post Oct 26, 2013 - 3:23 AM
EdinR-DrugB
Joined Oct 25, '13
thanks
start to translate
...... irina where are you(my wife she is from Ukraine)
Lo-Fi Version Time is now: November 29th, 2024 - 10:39 PM
