> Avalon Caliper Upgrade?
post Oct 27, 2013 - 7:27 PM
1994Celica
Joined Aug 5, '09
From West Texas, USA
I heard we can use Avalon calipers and they bolt right up. Is this true and will the Celica pads work with the calipers?
JDM Part King
post Oct 28, 2013 - 11:55 PM
mi645
Joined May 23, '12
From northridge,CA
Yes sir I can assure you it bolts up I have them on my car I even used stock caliper bracket on the calipers I got from abalone everything else is stock from my Celica gt
post Oct 29, 2013 - 9:51 AM
jordisonjr
Joined Jan 20, '09
From Winnipeg
Is this an upgrade from the stock brakes? Or is it the same caliper set up, just another option in sourcing parts?
My Celica!
post Oct 31, 2013 - 2:53 AM
mi645
Joined May 23, '12
From northridge,CA
It's an upgrade but honestly u won't feel much braking difference especially if I have ABS also most difference is when u brake at really high speed ur car won't shake like most stock gt do thanks to single position uneven worn pads and dics
post Nov 2, 2013 - 12:42 PM
BillyM81
Joined Mar 15, '11
From Belfry, kentucky
What are the years of Avalon caliper that we can use?
post Nov 2, 2013 - 5:56 PM
RabidTRD
Joined May 31, '11
From Rochester, NY
97 Avalon. Used the same pads and rotors as our car too. Doing this come spring.
post Nov 2, 2013 - 8:54 PM
BillyM81
Joined Mar 15, '11
is it just 97 Avalon or is it 97 and up Avalon. Does it have to be from an Avalon with abs or without
post Nov 3, 2013 - 8:29 AM
RabidTRD
Joined May 31, '11
From Rochester, NY
97 body style. So any of that same style. I believe it goes 95 - 99. Idk. I just picked a year and looked at part numbers and I can guarantee 97 is one if the years. ABS doesn't matter on toyotas from that generation for pad differences. All 6gc's take the same pad and rotor regardless of ABS.
post Nov 3, 2013 - 9:34 AM
BillyM81
Joined Mar 15, '11
Are reman calipers alright or is it better to get oem from a junkyard.
post Nov 3, 2013 - 9:09 PM
RabidTRD
Joined May 31, '11
From Rochester, NY
Reman are OEM castings with replaced internals. That's what reman means. So you're buying the same thing that was on your car from the factory usually.
post Nov 11, 2013 - 7:10 PM
NWCelica
Joined Oct 16, '07
From Seattle
Just want to be sure that these are a 100% direct swap
post Nov 12, 2013 - 8:02 PM
mi645
Joined May 23, '12
From northridge,CA
Its 110% direct bolt on swap
post Nov 14, 2013 - 8:38 AM
toyota123
Joined Jan 13, '12
From Georgia
Also 94-97 camry v6 with abs caliphate a direct bolt on and may be cheaper than the Avalon depending on where you go
97 Celica GT liftback DD/ project
96 corolla back up DD
post Nov 20, 2013 - 4:48 PM
NWCelica
Joined Oct 16, '07
From Seattle
QUOTE (RabidTRD @ Nov 2, 2013 - 3:56 PM) *
I went to rockauto and compared brake pad part numbers and they did not match.
post Nov 20, 2013 - 5:29 PM
SupraKid
Joined Aug 15, '10
From The Best Coast
So I am guessing the only upgrade to this is that the Avalon calipers are two pot compared to the GT which is one?
post Jan 8, 2015 - 5:14 PM
ILoveMySilly97
Joined Mar 8, '12
From Hanford/Fresno, Ca
QUOTE (toyota123 @ Nov 14, 2013 - 5:38 AM) *
They're direct bolt on also? Along with the same brake pads? Im guessing theyre twin pot also?
post Jan 8, 2015 - 6:39 PM
1994Celica
Joined Aug 5, '09
QUOTE (ILoveMySilly97 @ Jan 8, 2015 - 5:14 PM) *
http://www.6gc.net/forums/index.php?showto...6435&st=120 There's more info in that thread.
This post has been edited by 1994Celica: Jan 8, 2015 - 6:39 PM
JDM Part King
post Jan 8, 2015 - 8:32 PM
toyota123
Joined Jan 13, '12
From Georgia
Yeah direct swap. I didn't have to change anything other than the caliper itself
post Jan 14, 2015 - 2:23 AM
azn87
Joined Aug 2, '06
From bay area
how are those compared to 94+turbo mr2 front calipers?
post Jan 14, 2015 - 2:16 PM
BonzaiCelica
Joined Apr 24, '08
From Orange County, CA
QUOTE (azn87 @ Jan 14, 2015 - 3:23 AM) *
i told you read this thread. you judge for yourself which is better and easier to source
Lo-Fi Version Time is now: November 25th, 2024 - 2:52 PM
