> OEM lugs shank diameter
post Oct 28, 2013 - 11:26 AM
PegGTS
Joined Apr 15, '13
From Winnipeg, MB, Canada
Does anybody know the diameter of the shank for the OEM mag lug nuts? I need to get some lug nuts to put my stock wheels back on for the winter and just want to make sure I get proper fitting lug nuts.
2007 Impreza 2.5i - Daily
1994 Camry - Sold
1994 Celica - Sold :(
Click here to see my progress thread!
post Oct 28, 2013 - 11:52 AM
The_enD
Joined Apr 12, '13
From Bulgaria
12mm x 1.5
FS thread : Custom Celica parts made to order + more
Click the image to visit my FB page
post Oct 28, 2013 - 12:28 PM
PegGTS
Joined Apr 15, '13
QUOTE (The_enD @ Oct 28, 2013 - 12:52 PM) *
12mm x 1.5
I know that, I'm talking about the diameter of the shank at the end of the lugs that fits in the hole on the stock aluminum wheels. The lugs look like this:
What I'm looking for is the diameter of that bottom piece (the shank)
1994 Camry - Sold
post Oct 28, 2013 - 12:47 PM
The_enD
Joined Apr 12, '13
From Bulgaria
Can't you measure or use your current ones?
The end is rounded up, so even with the diameter known you may end up with a bit of a different shape.
post Oct 28, 2013 - 1:01 PM
PegGTS
Joined Apr 15, '13
QUOTE (The_enD @ Oct 28, 2013 - 1:47 PM) *
I don't have the wheels with me at the moment so I can't measure the size of the hole. And somebody had acorn style lugs on there before and you can tell that the wheel and the lugs were getting ruined from using them so that's why I'm looking for some OEM style mag lugs with the shank.
1994 Camry - Sold
post Oct 28, 2013 - 1:16 PM
The_enD
Joined Apr 12, '13
From Bulgaria
Scapyard/Ebay?
post Oct 28, 2013 - 1:26 PM
PegGTS
Joined Apr 15, '13
QUOTE (The_enD @ Oct 28, 2013 - 1:16 PM) *
Scapyard/Ebay?
I've been trying eBay but a lot of them state a different diameter for the shank which is why I'm looking for that length tongue.gif Although they aren't that much different (around 0.1"). Do you think that it would make much of a difference?
1994 Camry - Sold
post Oct 28, 2013 - 1:38 PM
The_enD
Joined Apr 12, '13
From Bulgaria
It really boils down to how much surface is touching between the two.
You can go to scrapyard and buy some from a corolla, maybe Paseo, mr2, Avensis. If you don't really care about how they look of course.
http://www.ebay.co.uk/itm/20-x-ALLOY-WHEEL...=item3377d9352e
Look at the list of similarities.
Maybe some aftermarket
http://www.ebay.com/itm/16-12X1-5-BLACK-SP...M-/130546817081
post Oct 28, 2013 - 1:41 PM
PegGTS
Joined Apr 15, '13
QUOTE (The_enD @ Oct 28, 2013 - 2:38 PM) *
Those ones are the acorn style lug nuts, they don't have the shank at the bottom that fits right into the wheel. That style is what I had on before and was damaging the wheel
I think I might just go with these, then I know for sure they will work
http://www.ebay.com/itm/94-95-96-97-98-99-...D-/141079558637
1994 Camry - Sold
post Oct 28, 2013 - 1:51 PM
The_enD
Joined Apr 12, '13
From Bulgaria
I am lost.
I have stock steelies and the only part that's touching is this.
Same with my OZ
post Oct 28, 2013 - 1:59 PM
PegGTS
Joined Apr 15, '13
QUOTE (The_enD @ Oct 28, 2013 - 1:51 PM) *
I am lost.
Same with my OZ
Are you using stock lug nuts like these or aftermarket ones? From what I understand, with aftermarket acorn style lug nuts, they reach the studs but just barely and it isn't good for the wheels or the lugs and it isn't safe. However with the stock mag style lug nuts, they reach all the way into the hole like this picture on the right:
You can see in this picture that if you try using the acorn lug nuts (On the left) in our stock wheels (the wheel on the right), it doesn't quite fit.
I hope that makes sense...lol
1994 Camry - Sold
post Oct 28, 2013 - 2:05 PM
The_enD
Joined Apr 12, '13
From Bulgaria
And all these lug nuts you want to buy are going to be on what rims?
post Oct 28, 2013 - 2:14 PM
PegGTS
Joined Apr 15, '13
QUOTE (The_enD @ Oct 28, 2013 - 3:05 PM) *
My stock rims. For the winter
1994 Camry - Sold
post Oct 28, 2013 - 2:34 PM
The_enD
Joined Apr 12, '13
From Bulgaria
You should mount one in dry fit and see how things look. I have steelies, tho I am not sure if they come exactly from a Celica, but they come from a Toyota. I don't have factory lug nuts, but they are not some fancy aftermarket either.
But that lug on the right will not sit nice on both my summer and winter rims.
post Oct 28, 2013 - 2:41 PM
richee3
Joined Jun 29, '08
From Denver
The short lug nuts in the picture you posted are shorter than stock 6th gen lug nuts. The shorter ones are from a Corolla, 7th gen Celica, or Sienna. They should still work.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
Lo-Fi Version Time is now: December 4th, 2024 - 10:56 AM
