Gt4 wont start |
Gt4 wont start |
Oct 28, 2013 - 6:35 PM |
Enthusiast Joined Oct 28, '13 From Chicago il Currently Offline Reputation: 0 (0%) |
So i imported a gt4 to illinois! It was running fine on saturday until it died out when i gave it gas
I go to it today monday it wont start sounds like the timing belt is off checked the timing it was a brand new belt. Nice and tight how ever the car had no compression! I disconnected the intercooler and put it back on now its got compression and cranks healthy! There is spark and plenty of fuel pressure but i saw the ground cable smoking so i replaced it it dosent smoke now. Any ideas? im anxious to drive this thing thanks! |
Oct 28, 2013 - 7:31 PM |
Btw i cant understand how a car goes from having no compression to having compression it doesn't make any sense!
Oct 28, 2013 - 9:56 PM |
No, it doesn't make sense which means you probably did something wrong doing the compression test the first time. Sounded like no compression or read near zero on a compression tester?
Oct 28, 2013 - 10:45 PM |
Welcome to the boards! A real GT-Four in Chicago, eh? We have a couple of meets a year at Starved Rock. You'll have to come to a few of them. We may be having a small get together soon in the city as well.
If you have spark and fuel, you should have ignition. Did you happen to check the timing when you checked the belt? It's possible that the belt skipped a tooth. Is your check engine light on when you turn the key on? You said it was running fine until you gave it gas, so it was running and then died? Smoking grounds are never good. Was it a stock ground? Corroded or pretty clean? Going based off of the ground, I'd start checking fuses to make sure everything is good. Post pictures of your new car. I call dibs on a ride in this beast! -------------------- "Employ your time in improving yourself by other men's writings, so that you shall gain easily what others labored hard for." -Socrates. Even Socrates told us to use the search button!
Oct 28, 2013 - 10:48 PM |
Enthusiast Joined Aug 4, '06 From Chicagoland Currently Offline Reputation: 9 (100%) |
Welcome.
Subscribed. -------------------- ~bloodMoney
Oct 29, 2013 - 6:18 AM |
Enthusiast Joined May 16, '10 From Raleigh Currently Offline Reputation: 12 (100%) |
Pictures under the hood would be helpful. What were the results of your compression test, and what did you use to check it? You need to ensure that ALL ground straps are connected. Lack of a ground strap could easily burn an over stressed ground strap. Either way, it sounds like your problem is electrical.
Oct 29, 2013 - 8:17 AM |
No, it doesn't make sense which means you probably did something wrong doing the compression test the first time. Sounded like no compression or read near zero on a compression tester? I used a compression tester i also took the spark plugs out and crancked it didnt hear or feal air till the secound time! |
Oct 29, 2013 - 8:24 AM |
Welcome to the boards! A real GT-Four in Chicago, eh? We have a couple of meets a year at Starved Rock. You'll have to come to a few of them. We may be having a small get together soon in the city as well. If you have spark and fuel, you should have ignition. Did you happen to check the timing when you checked the belt? It's possible that the belt skipped a tooth. Is your check engine light on when you turn the key on? You said it was running fine until you gave it gas, so it was running and then died? Smoking grounds are never good. Was it a stock ground? Corroded or pretty clean? Going based off of the ground, I'd start checking fuses to make sure everything is good. Post pictures of your new car. I call dibs on a ride in this beast! Thanks! Starved rock ay! I got pics posted in my profile! Ill post more pics soon! Already checked fuses Welcome. Subscribed. Thank you Pictures under the hood would be helpful. What were the results of your compression test, and what did you use to check it? You need to ensure that ALL ground straps are connected. Lack of a ground strap could easily burn an over stressed ground strap. Either way, it sounds like your problem is electrical. Ill get some pics of it |
Oct 29, 2013 - 11:17 AM |
if you are getting spark, fuel, and compression, then it should be running.
Oct 29, 2013 - 1:19 PM |
Ok so now i figured stuff out cylinder 1 has no compression and cylinder 2 3&4 read 150psi i see the piston moving up and down but no compression im guessing bad rings or bent valves on cylinder one! Anyone got diagrams for timing im taken the engine apart! Btw my compression gauge was messed up bought a new one lol
Oct 29, 2013 - 4:47 PM |
pour a cap full of oil into cylinder one. If you get a bump in compression then it's the rings. If not it's the valves. Unlikely for it to be valves, because the 3sgte engines are not interference engines, but hey...anything can happen.
Here's the link for just about anything you'll even need to know about overhauling your engine. http://gt4.mwp.id.au/ This post has been edited by bsamps4: Oct 29, 2013 - 4:48 PM -------------------- |
Oct 29, 2013 - 7:12 PM |
Burned a valve maybe? Do a leak down test, you'll want an air compressor someday anyway.
Oct 30, 2013 - 2:51 AM |
Valves stuck open on cylinder one was the cause! Pistons are still good!
Oct 30, 2013 - 7:19 AM |
Bent valves stick open, sucks. Time for valves and guides!
Lo-Fi Version | Time is now: November 25th, 2024 - 9:03 PM |
